摘 要:采用脉冲激光沉积技术在蓝宝石(α-Al2O3)衬底上制备了不同Mn掺杂浓度的ZnO薄膜.实验结果表明,合适浓度的Mn的掺人,有利于ZnO:Mn薄膜(002)生长而不形成Mn的氧化物,同时,所有的薄膜均呈现出了室温铁磁特性.随着Mn含量的增加,薄膜光学带隙红移,对应的Mn离子电荷转移跃迁吸收逐渐增强,磁化强度逐渐减小.实验结果支持薄膜的铁磁性起源于替位的Mn离子之间的长程铁磁相互作用,Mn离子增加导致平均磁矩减小,可归因于邻近的Mn离子密度的增加引起的反铁磁作用增强,相对应的sp-d交换作用逐渐增加. / }. S3 j9 y. ~$ C
1 Q/ w, o! [0 z" e
关键词:Mn掺杂ZnO;sp-d交换;铁磁特性
, o0 r s1 H: U! x3 g( L0 H* a9 m, o9 }* j8 U
分类号:TB7 文献标识码:A . z1 M2 Q4 z4 Z
+ w/ k! ^9 B* ?9 p+ f
文章编号:1672-7126(2008)增刊-022-04
/ W- ]* f3 }& h/ e8 d
% C+ v# h7 H8 k3 j4 b! w 参考文献: + {# A0 k) e6 ^7 W+ p9 @0 l
5 j# K6 j# P. l" e! B: ^0 w' U! N [1]Wan Q,Li Q H,Chen Y J,et al.Fabrication and ethanol sensing characteristics of ZnO nanowire gas sensors[J].Appl.Phys Lett.,2004,84(18):3654
8 {+ a; \; P2 \0 H: z* W- u% S/ r! h3 p+ H& K6 _
[2]Dietl T,Ohno H,Matsukura F,et al.Science,2000,287:1019
& L) A3 T, U" y. }
, |# K [- d5 W [3]Oiwa A,Slupinski T,Munekata H.Control of magnetization reversal process by light illumination in ferromagnetic semiconductor heterostructure p-(In,Mn) As/GaSb[J].Appl.Phys.Lett.,2001,78(4):518 , ?( R- G& k: R1 v- y
& `( s/ J: s. o0 r# c, c8 _ [4]Ueda K,Tabata H,Kawai T.Magnetic and electric properties of transition-metal-doped ZnO films[J].Appl.Phys.Lett.,2001,79(7):988 ^5 b s1 N! U* u) w% `) A$ a% r
" \0 e7 I' Z0 }
[5]Sharma P.Nat.Mater.,2003,2:673 r( V1 j# P3 z; k7 c; B
; x. S9 i" b7 P; }! p) w x# V [6]Change V Q,Wang D B,Luo X H,et al.Synthesis,optical,and magnetic properties of diluted magnetic semiconductor Zn1-xMxO nanowires via vapor phase growth[J].Appl.Phys.Lett.,2003,83:4020 " B$ L. f, O9 @% V6 R/ ]; R9 O
) _9 }3 D: U; s+ L9 ~. I4 m
[7]Ankiewicz A O,Carmo M C,Sobolev N A,et al.Electron paramagnetic resonance in transition metal-doped ZnO nanowires[J].J.Appl.Phys.,2007,101:024324 7 w% {4 H( w% V1 B6 ^3 E
: ~: X9 x8 n% [' k `! F
[8]林益梅,叶志镇,陈兰兰,等.ZnO薄膜的缺陷研究进展[J],真空科学与技术学报,2006,26(5):385-391 6 t, l4 t9 i. P2 B# F7 y1 P$ P
2 _4 {" a3 K& ?, _1 d9 e [9]Fukumara T,Jin Z,Ohtomo A,et al.An oxide-diluted magnetic semiconductor:Mn-doped ZnO[J].Appl.Phys.Lett.,1999,75:3366
$ r: T: s% I" P! I7 n* y; |+ ^1 C5 T( x0 Q
[10]Bylsma R B,Beeker W M,Kossut J,et al.Dependence of energy gap on x and T in Zn1-xMxSe:The role of exchange interaction[J].Phys.Rev.B,1986,33:8207 : g1 B9 ^2 \, e- S
8 i, Z$ K& l n( p" F% {! h3 f) N3 ^ [11]Mi W B,Bai H L,Liu H,et al.Miernstructure,magnetic,and optical properties of sputtered Mn-doped ZnO films with high-temperature ferromagnetism[J].J.Appl.Phys.,2007,101:023904 3 y. b0 J$ G" s+ ?. H# @
) d" F6 O" Q/ r [12]Grimmeiss H G,Oxren C.Identification of deep centers in ZnSe[J].J.Appl.Phys.,1977,48:5122
' l% \9 |& i5 y; ?6 P3 e$ |
& B6 l8 v1 _/ Z6 E3 u* b) g [13]Kim K J,Park Y R.Spectroscopic ellipsometry study of optical transitions in Zn1-xMxO alloys[J].Appl.Phys.Lett.,2002,81:1420 $ V3 r4 Z+ q5 e' j( Y
; C3 ^# g2 B: R7 X. J1 G2 U
[14]Yoo Y Z,Fukumura T,Jin Z W,et al.ZnO:CoO sofid solution thin films[J].J.Appl.Phys.,2001,90:4246
3 S0 T& e+ t: q6 B+ B- q2 K; ^; c" _& k
[15]Ivill M,Pearton S J,He Y W,et.al.Magnetization dependence on cartier doping in epitaxial ZnO thin films co-doped with Mn and P[J].J.Appl:Phys.,101,2007:123909
( v- W/ v$ S2 h8 ^) n/ C8 s( b7 K: u! X) c
[16]Iusan D,Sanyal B,Eriksson O.Theoretical stndy of the magnetism of Mn-doped ZnO with and without defects[J].Phys.Rev.B,2006,74:235208
( K+ l; F7 [7 a: J
3 D' Q3 \8 \# _ [17]Neal J R,Behan A J,Ibrahim R M,et.al.Room-Temperature Magneto-Optics of Ferromagnetic Transition-Metal Doped ZnO Thin Films[J].Phys.Rev.L,2006,96:197208 7 q# J+ u) r/ M1 D5 o
. L% K/ d. ~" E! v" G6 a [18]Szczyko J,Mac W,Twardowski A.Antiferromagnetic p-d exReview B,1999,59:12935 |
