j1 @! Z+ v3 Z- ~
5 T6 b m& Q+ ^! f9 d2 H
" f8 d" f* J; ^- @
5 Y K2 z" K) v' e# C# pWoodhead Publishing Series in Electronic
! z8 e7 K) u! v9 j( a( t9 R" e6 E9 vand Optical Materials
0 Z- H3 Y' X0 ?8 \& F/ R6 }' u: fOptical Thin Films and
2 S) L; Z: ~; x, V- Y# W6 WCoatings# Y( S6 y( J# a; X) L: N
From Materials to Applications
6 k! F& p' m5 H8 a: k+ X& |Second Edition) n6 x8 S" M3 F' ~
Edited by+ F. J( k3 b H: e4 }% o: x5 A
Angela Piegari& L7 T4 g }5 F, \8 Z5 O8 o9 @
Contents; {7 l0 n" F' e$ z- X
Contributors ............................................................................................................xix3 F+ M& H. W3 u& w% a. W$ F6 J
Preface to the First Edition ................................................................................. xxiii
% I+ N* L4 z4 ?4 `6 y: oPreface ................................................................................................................ xxvii
6 L. b4 m+ F! H& J4 t* M" u& EPART I DESIGN AND MANUFACTURING OF OPTICAL$ Q4 ?! J1 C% C& m* ^
THIN FILMS AND COATINGS% V9 \% M$ L2 a4 |4 g
CHAPTER 1 Recent developments in deposition techniques
& { U) M' s4 S- Ifor optical thin films and coatings...............................3
, s' Z9 Z4 n- L; P C. LH. Angus Macleod1 ` ^- z6 k T/ o$ _' H1 {( C
1.1 Introduction.....................................................................................3
) s: i4 M% Y6 `" P% g3 ?, t1.2 Early Processes for the Deposition of Optical Coatings ...............4
. W+ `9 k0 ^: I# R1.3 The Energetic Processes .................................................................6
8 u+ w4 n$ z' P1.3.1 Ion-Assisted Deposition........................................................6; v* x- g4 M8 w* Q3 m9 z
1.3.2 Ion Plating.............................................................................84 @$ O+ k" A/ B6 n9 G3 C2 E
1.3.3 Sputtering............................................................................104 g6 c7 S' H+ r8 g
1.4 Cathodic Arc Evaporation ............................................................15
4 q1 h& B; y# Q1 `/ e, c Y% L3 j7 [. D6 N1.5 Pulsed Laser Deposition ...............................................................15* L) N; K; s' O8 O
1.6 Chemical Vapor Deposition .........................................................163 U# Y" @ {) {1 ]& f# n- ^
1.7 Atomic Layer Deposition .............................................................17
7 R: L h+ N0 ]; {( ]1.8 Sol-Gel Processes .........................................................................18
$ |6 m1 L9 N5 }' _% y; o1.9 Etching ..........................................................................................18( P+ b y7 E2 B+ s9 o# u5 s: V
1.10 Other Techniques..........................................................................19
; W( {& e" }) I/ S. ]0 X1.11 Conclusion ....................................................................................19# o* b" {* J0 y, T) E% V3 A
References.....................................................................................202 B; B: j% o( `5 A! o$ k2 w/ N5 r! g# }
CHAPTER 2 Design of complex optical coatings...........................25
0 I% Y4 x4 Y: }8 U3 s% WPierre G. Verly, Daniel Poitras: s5 l8 q T2 X1 d% _/ U
2.1 Introduction...................................................................................25 o+ Q/ |( e8 d+ M2 |+ m) ]
2.2 Modern Numerical Thin Film Synthesis Techniques ..................27. b. w* P3 v- I" V3 `4 ?
2.2.1 Fourier Transform Method.................................................27
( {8 g" g3 p5 }& C* U4 k9 q- L$ l2.2.2 Inhomogeneous Refinement ...............................................30
/ |/ C. i& a8 ]! P+ }1 M+ n$ R2.2.3 Needle Method ...................................................................32
; {8 Q5 m4 F) d/ h) u2.2.4 Global Optimization ...........................................................34* Y7 Z7 W, ?6 c: B$ \# D: p0 \- a
2.3 Manufacturability Issues...............................................................37
# a* q$ G" L7 P5 d. W2.4 Hybrid Design...............................................................................40) C( [+ J' N6 [7 K
2.4.1 Waveguide Facet Coatings.................................................41
, |+ D" ^& ]- i6 m h* j: ~7 U: `6 ~2.4.2 Structured Coatings ............................................................44
+ v0 j( x6 i i7 Z8 z/ `2.4.3 Solar Cells...........................................................................48
; ]+ j' }( d: N* ^( b2.5 Conclusion ....................................................................................52" ]# F' S/ f( ~- j4 z1 D- t- b
References.....................................................................................53- i- O% z6 l @* u$ i
Further Reading ............................................................................64
6 _1 M( i- M; @2 JCHAPTER 3 Optical monitoring strategies for optical coating0 m7 r% r% F; @+ U+ `. \& b6 b! X
manufacturing .............................................................65
, G* ^; J) `' M$ S* N1 KAlexander V. Tikhonravov, Michael K. Trubetskov, Tatiana
. F3 K+ `+ l( z2 KV. Amotchkina
' S* s0 ]0 V3 x' c5 X+ s* C3 v. e3.1 Introduction...................................................................................65
0 x" |9 Y) Y; M3.2 Classification of Optical Monitoring Strategies ..........................675 Y. x0 v+ H4 _, a
3.3 Turning Point Optical Monitoring and Error Self-Compensation( n7 M5 w! W5 {, k
Effect.............................................................................................69
+ Y8 ]3 w4 b; J5 N( c3.4 Level Monitoring: Passive and Active Monochromatic
4 j" s2 T; @- ]5 r% y: ]* _0 n$ C0 XMonitoring Strategies ...................................................................75
6 N2 X- n4 \4 X: x7 b3.5 Monitoring by Swing Values .......................................................85
* I5 X; o- ^4 m0 m. d( l& n3.6 Direct Broadband Optical Monitoring .........................................89
7 x' F. G' l6 H2 ` e' M) T3.7 Indirect Optical Monitoring Strategies.........................................92
8 a3 k9 s2 ]( y" u( |7 A% Y V$ A9 t+ i& M3.8 Conclusion ....................................................................................97
2 N( P: J' N N4 s( EReferences.....................................................................................99& s: y6 \; |6 H% k2 s
CHAPTER 4 Production strategies for high-precision optical
' P# g: H$ V0 w+ {5 T6 bcoatings .................................................................... 1032 [& p) @2 C$ B, h; G! J
Henrik Ehlers, Detlev Ristau
8 `$ S; `0 s3 O. _' ^, U4.1 Introduction.................................................................................103
0 [% g- i3 X3 T5 w9 t; {: y4.2 Basic Concept of Deterministic Production...............................105
& { h( i/ s0 ?# h8 x2 v4.3 Optical Broadband Monitoring ..................................................107 t& J: m6 o. R* w1 g4 O+ A
4.4 Hybrid Thickness Monitoring Concepts ....................................112
( A8 S# N+ Z7 D2 B# v( @' m; a" F4.5 Virtual Deposition System .........................................................114
* o) K# ? }7 [: I( O" A1 u4.5.1 Deposition System............................................................115
: s/ U3 M; @4 \3 x, N" L: m4 X4.5.2 Online Measurement System............................................116
2 V0 G9 c# M: x2 w' f4.5.3 Process-Tracing Algorithm...............................................116
, f! z+ G, G) Q* E9 `5 {" M; U4.5.4 Application Example for a VDP Analysis .......................117
# t4 B, T- W/ Q/ M4.6 Direct Online Correction Tools..................................................118
' Q6 s% p8 {, c7 N$ ?4.7 Design Stability in Production Processes...................................120
# b" d1 g2 `7 t4.8 Deposition Control of Coating Systems with Continuous
$ [8 r; o& l# [: k- f! D" B; B% NRefractive Index Variation .........................................................125
% U: F* b4 f# m4 a ?4.8.1 Production of Material Mixtures......................................126 l' A6 g/ U9 f, K% w! Q
4.8.2 Deposition Control of Rugate Filters ...............................1328 }; e8 E) M( z9 e( f
4.9 Conclusion ..................................................................................135- o# @3 ?3 b0 F! W" a
References...................................................................................136
5 L6 z9 _$ T4 F7 U6 B* wFurther Reading ..........................................................................140/ ?# j, Z. p+ P" p/ E+ ]9 i
vi ContentsPART II UNCONVENTIONAL FEATURES OF OPTICAL THIN3 a" o% {* ]( S- K
FILMS AND COATINGS
% N- ]* n3 r" m5 ]CHAPTER 5 Complex materials with subwavelength inclusions
/ R; T8 v3 d( y5 B' L6 ]# dfor optical thin film applications ............................. 1438 O1 {9 _( o. h+ O$ @" G
Anna Sytchkova
$ i. T! V i" F+ G5.1 Introduction.................................................................................143; H* t' u2 h+ R) F
5.2 Physics of Some Classes of Novel Materials with5 R c" r/ l: c/ m! e ^
Subwavelength Inclusions ..........................................................145; O8 S; m/ u9 o
5.3 Ceramic Matrix With Embedded Nanostructures......................147# _* k5 l( |- _9 |
5.3.1 Materials With Quantum Dots .........................................148
( q$ k% o8 [) x! j) U5.3.2 Nanoclusters in Periodic Arrays (Metamaterials)............149
" c# k! F+ s( G F+ X0 z5.3.3 Effect of Small Random Disorders and Imperfections
5 V; j {6 ]# t! B, j: ]1 Vin Metamaterials ...............................................................154
$ D$ |; `* Z% N5 m- t% k: S5.3.4 Composites of Random Elements ....................................1541 m5 S0 q; Y; H5 w c& c7 U
5.3.5 Coatings Containing Thin and Ultrathin Metal Layers0 u9 z) l7 @: o7 C7 P3 z" [
and Coatings Containing Metasurfaces............................1557 S6 Y5 d1 J' L7 o5 p4 }
5.4 Searching for Alternative Materials for Resonating
- v8 u5 t" L& N& C. MInclusions ....................................................................................156% D, l- [' L; w ^# n- t$ [
5.4.1 Alloys and Intermetallics: Novel Metal Materials ..........1577 c4 ^* K# D! Y5 X( g. ?3 G$ Q
5.4.2 Semiconductors and Dielectrics .......................................160! B3 M/ P5 B$ b0 ~) B' A/ y
5.5 Characterization of Novel Materials with Subwavelength# d9 R9 D; P, U3 y9 l
Inclusions ....................................................................................1620 z' Q$ ]7 ]. {+ w2 R+ {
5.5.1 Optical Characterization Techniques for Complex
. m; {" z" Z7 o: C6 ]* o. h; fMaterials ...........................................................................163
3 `* I: \" K" ]% s5.5.2 Local Properties of Nanostructured Materials .................165+ D- q5 v+ l0 Z
5.5.3 Effective Macroscopic Parameters...................................166
" ~' Y" d6 c* A; n; r5.5.4 Complex Materials and Ultrathin Metals in Multilayers.1686 O8 H- b; @) _* I/ I6 l
5.6 Conclusions.................................................................................172
: Y( j. i% R; }! n9 DReferences...................................................................................173
* c3 ? j5 P$ kCHAPTER 6 Scattering properties of random structures- w! h2 g% j9 g& Y9 L: e U
in thin films............................................................... 187
( I* [* a5 t* ?3 v; I* B jGerard Berginc, Alexei A. Maradudin4 B1 W+ {+ X/ }" m6 A6 P7 H: j: }
6.1 Introduction.................................................................................187
* Y f3 b! q# b2 t2 h6.2 Numerical Solution of Reduced Rayleigh Equations
/ v2 B8 P3 l; c$ L4 _for Scattering of Light From Dielectric Films With 1D9 K; x$ j1 r2 r: v+ }7 ]* P
Rough Surfaces...........................................................................189
. D* k0 W. ?2 Y7 W! C6.2.1 A Film With a 1D Randomly Rough Vacuum-Dielectric
% f) J/ f$ Z1 G) t4 P- UInterface Deposited on the Planar Surface of a Perfect$ M: f: [' y& `5 }' n7 p9 Z
Conductor..........................................................................1906.2.2 A Film With a Planar Vacuum-Dielectric Interface$ W% ], L/ }9 k, I( b% {1 w8 F, X
Deposited on a 1D Randomly Rough Perfectly/ o! L( y& {& E- w8 s+ j! O
Conducting Surface ..........................................................196
/ W2 S: p3 L2 s6.3 Reduced Rayleigh equations for the scattering of P- and; _: y6 e4 m, g' }
S-Polarized Light From, and Its Transmission through, a Film
$ c' |( H: z$ B, o( W# rWith Two 1D Rough Surfaces ...................................................200
% `1 P2 s+ I; c4 n6.3.1 p-Polarization....................................................................2033 o" p4 w9 n' ]0 e! j
6.3.2 s-Polarization ....................................................................207( h" J0 K# c. L, u0 `+ j4 ?3 B
6.3.3 Results...............................................................................209+ B$ F* R. \+ M& q9 X4 b) |
6.4 Numerical Solution of the Reduced Rayleigh Equation
7 i! _ \& Z( V7 J8 Rfor the Scattering of Light From a 2D Randomly Rough0 T' B3 b; L, e, }" F; o. e' H
Penetrable Surface ......................................................................213
: u/ Q( {! V7 q5 T! \8 Z* E) ~6.5 Scattering of Light From a Dielectric Film With a 2D Randomly8 \7 h& P4 i2 f6 C1 A+ S i% B
Rough Surface Deposited on a Planar Metal Substrate.............216/ N- ~+ F! e; v; R
6.5.1 Scattering of Light From a Dielectric Film With a 2D
) L6 k0 D. u! F0 f9 O/ tRandomly Rough Surface Deposited on a Planar Metal
* w. L- o/ m; ]! Y, T7 G8 J9 N; HSubstrate............................................................................218
6 o0 J, C4 H9 [3 H4 J/ ~+ E4 N1 {6.5.2 A Dielectric Film With a Planar Interface With a5 W" _" M0 [# d* e$ c X
Dielectric Superstrate and a 2D Randomly Rough" n x* E6 H) ^8 k) \. c Z
Interface With a Dielectric Substrate...............................224
) l8 i+ r; j/ \ D0 q) F- t6.6 Analytical Methods for the Scattering From a 3D Film With
. d; N& [* @; Y; `" A2 mRandomly Rough Surfaces .........................................................2296 x! P2 F m( X7 e" d4 j% l
6.6.1 Definition of the Scattering Matrix..................................2309 N8 @, g# ]4 t" k+ a: O4 v6 K# J5 d
6.6.2 The SSA and the SPM for a 2D Rough Surface .............233
& ?% S7 u+ y7 v( V a3 j9 S0 H6.6.3 The SSA and the SPM for Slabs With Randomly
0 S! S" d! W5 }: h4 cRough Boundaries ............................................................240' e1 K% ^- i0 b) U7 i
6.6.4 Conclusions.......................................................................247% M% y) [: N9 o
6.7 Theoretical Methods for the Scattering of Polarized Light
( a! n3 e; a2 RFrom Randomly Rough Interfaces and Random Media............247
' @# j$ Z9 ~! c6.7.1 Specific Intensity and Cross Section................................248
# t. ]5 V+ q+ g: v" V% g+ Q6.7.2 Specific Intensity and Bethe-Salpeter Equations.............253
8 Y; d$ g2 l5 _& t6.7.3 Effective Permittivity .......................................................255
/ X% Q+ O& o" {) e8 g; ~6.7.4 Expression of the Intensity Operator P11 .........................2569 ~$ J4 i2 R' {! m9 Z: F6 w; e3 d
6.7.5 Expression for the Incoherent Intensity and the Green) Y; |( t- |+ \/ U0 a
Tensors P11 .......................................................................2596 f$ N6 A0 J% s# c+ P& j0 d. v
6.7.6 Coherent Backscattering...................................................265
) I0 Q* v: P- [5 q5 s4 c6 k+ e! v. _6.7.7 Conclusion ........................................................................273& b/ ?" _6 F1 {/ I
6.8 Applications ................................................................................2737 ^& d( `, @5 Z; i/ b6 i4 p- Q+ T
6.9 Conclusion ..................................................................................281
7 W% {: a+ {1 cAppendix.....................................................................................281
' B" f' g. n$ [/ p( Pviii ContentsA.1 Definitions of the Scattering Matrices for a Single Rough( R6 {) y2 s- Y- V
Surface ................................................................................2815 u( r) p7 N4 F6 j
A.2 Mueller Matrix and Tensor ................................................282& a& o8 Q$ y1 _- w3 p: C2 \
Acknowledgments ......................................................................284
% H% C% w% G; g1 w" kReferences...................................................................................284( V0 n# B. O3 N2 ]' M' W
Further Reading ..........................................................................2890 f( B8 Z y/ u! {9 s8 x8 B
CHAPTER 7 Optical properties of thin film materials at short# v/ s" n6 G' S( \6 s! N
wavelengths .............................................................. 291
4 w4 B; a" @7 R0 d$ F1 QJuan I. Larruquert
( |1 D1 O4 \, {$ U+ s: n+ f* \7.1 Introduction.................................................................................291( T/ x; [# o! b5 w1 u/ l
7.2 Material Behavior Over the Spectrum .......................................291+ |# m+ O4 q. l- I b/ X$ Q
7.3 Reflection and Transmission in Absorbent Materials ...............2944 h- a/ I% L1 D6 b8 _. E9 D2 T+ k
7.3.1 Roughness and Scattering ................................................296+ n/ Q1 L( `+ I- @$ s4 b
7.4 The Optical Constants of Materials at Short Wavelengths .......299
; r/ P7 n J: Z7 V9 B7.4.1 Interaction Mechanisms Between Photons
6 Z% [# H, y0 I- X" e* ^, m$ fand Matter.........................................................................299# l# f4 c8 `7 g' z& o! Y
7.4.2 Transparency Cutoff of Dielectrics ..................................300
) e5 [+ {; ?2 J4 u$ h0 S) s7.4.3 Free Electron Metals ........................................................301
) \0 c0 ?$ \/ o/ z6 Q |7.4.4 Tightly Bound Electrons: Atomic Scattering
9 ]) W y! c: b# WFactors...............................................................................303
6 G" V: N+ Z3 m0 M( t: i2 ?7.4.5 Absorption Edges..............................................................306
- D+ d& h/ u7 K4 b, c& T0 v) G7.4.6 Optical Properties at Higher Energies..............................309
# `8 z$ D- q3 Y# @+ A7.5 Link Between n and k: Kramers-Kronig Analysis.....................314
) j* q J5 i- d' i4 @8 L7.6 Experimental Determination of Optical Constants ....................315
7 ~9 E# \* G# x j. f# z) v7.7 Specifics of Optical Coatings at Short Wavelengths.................318
8 ^2 s3 U. t4 t x7.7.1 Transmission Filters .........................................................318+ `8 A+ y: C! `4 p" a
7.7.2 High-Reflectance Coatings...............................................321
# ]) D0 G1 o& l. s. o7.7.3 Linear Polarizers and Phase Retarders.............................332
( N* j9 d7 O3 N% q" V7.8 Conclusion ..................................................................................341
# @/ t& ^, a0 g& j7 nAcknowledgements.....................................................................342
/ _+ V8 i) ~ B* E nReferences...................................................................................342% _& w- n1 }% R/ Z
CHAPTER 8 Controlling thermal radiation from surfaces............ 357* J: U! g# \2 I$ K! X5 W, P
Carl G. Ribbing, G& I% ~: d& H; y+ ] G2 r/ U
8.1 Introduction.................................................................................357
3 I3 {2 K$ n0 z8.2 Blackbody Radiation ..................................................................359
: Q, e! M& o# h" U1 _; }6 U. i。。。。。。。资料寻找不易,请回复下载
, q. H1 R6 I6 E9 ]% a/ m, G9 C) ] [7 s! p3 O! s, @) d
& c7 u3 P4 c, z
: L) H/ N2 b4 V- W7 P8 T; \9 ]6 ?* R$ o1 h
