TiO2薄膜折射率的调控方法 摘 要:采用电子束蒸发技术及其辅助工艺制备了TiO2薄膜,利用X射线衍射(XRD)、X射线光电子能谱(XPS)和原子力显微镜(AFM)对薄膜的组织结构进行了表征,采用紫外可见分光光度计研究了TiO2薄膜的折射率变化.结果表明:传统电子束蒸发镀制的TiO2薄膜的折射率低于块体值,通过调节氧气压、沉积速率和衬底温度可在1.97~2.22范围内调控其折射率;采用离子束辅助轰击可使薄膜致密化,获得折射率在2.06~2.42范围内变化的TiO2薄膜;利用斜角入射沉积可控制薄膜生长角度与孔隙率,实现折射率在1.71~2.18范围内的调控.[著者文摘]
1 M" f' K' H. ]1 l& B% j% X. N1 Y5 \& [# I5 J5 X* W
关键词:薄膜 折射率 电子束蒸发
h9 E: [0 B/ \6 Q. _$ P
, n: L1 v: ]7 Q1 Q分类号: O484.41[著者标引]4 S& y' ^( x* a( J: o" N
文献标识码:A$ ~) o; B. ~( a( @, k* h& b
文章编号:1674-2974(2011)09-0059-05. d/ J! R% d# i' X: Q
栏目信息:材料科学 N/ L) O; g& K2 n' D
$ D* P2 o* W, A' a) C相关文献:主题相关 全文快照 6 x8 M/ F) h, a7 I9 X) X
4 f" i. x, ]' [: X+ t4 Y" I% n& {' j0 Q: r0 l: ?2 o, U
Regulation of the Refractive Index of TiO_2 FilmsZHOU Ling-ping,LUO Xiao-lan,ZHU Jia-jun,PENG Kun,LI De-yi,LI Shao-luCollege of Materials Science and Engineering,Hunan Univ,Changsha,Hunan 410082,ChinaAbstract:TiO2 films were prepared by electron beam evaporation(E-beam).X-ray diffraction(XRD),X-ray photoelectron spectroscopy(XPS) and atomic force microscope(AFM) were applied to characterize the film's structure.UV-visible spectrophotometer was used to analyze the changes of refractive index(RI).It has been found that the RI of TiO2 film prepared by E-beam is lower than that of the bulk.It can be regulated within 1.97~2.22 by controlling O2 pressure,deposition rate and substrate temperature.Compact film with RI within 2.06~2.42 is obtained by ion beam assisted deposition.Glancing angle deposition can realize the regulation of RI within 1.71~2.18 by controlling the growing angle and the porosity of films.[著者文摘]
/ {7 K- R1 T* ~: a7 ~# _. n. w* J( m* S
Key words:films; refractive index; electron beam evaporation
0 d; E, K7 B. g! X7 _$ H9 a
$ [. M* Y2 ]4 Q; p" Z
1 v0 F' V% k1 N3 [0 }http://115.com/file/c2m1jm9t#
" O* W+ S- a4 S/ P6 H# u2 ^8 DTiO2薄膜折射率的调控方法.rar- J/ B9 @+ j3 n+ |- }
2 s- H! |0 |) r. {
/ O5 B. I: Q- e: r( s7 t; Q
! K% u3 J E% T+ h
