高损伤阈值三倍频分离膜王孝东[1,2] 张锦龙[1,2] 马彬[1,2,3] 焦宏飞[1,2,3] 丁涛[1,2] 程鑫彬[1,2][1]同济大学精密光学工程技术研究所,上海200092 [2]上海市特殊人工微结构材料与技术重点实验室,上海200092 [3]同济大学航空航天与力学学院,上海200092摘 要:设计了Nd:YAG激光用三倍频分离膜,膜层材料为SiO2和HfO2。经过优化,膜系在355 nm处的反射率在99%以上,在532 nm和1 064 nm处透射率也在99%以上。采用电子束蒸发技术,在熔融石英基底上制备了样品,经测量,制备的分离膜光学性能与设计值接近。分离膜在355 nm激光辐照下的损伤阈值为5.1 J/cm2,并用微分干涉显微镜表征了薄膜损伤形貌。[著者文摘]/ G4 D: G" m7 L0 E7 p/ e
- O: S# v9 O. r& @% b) f0 \% a* T关键词:三倍频分离膜 电子束蒸发 激光损伤阈值 光学薄膜
8 Z' g8 l' v2 y7 C
+ Q8 Y* r/ o+ Y! @分类号: O484.4[著者标引]$ S- i$ H# x. s9 {- Z' o5 V
文献标识码:A8 Z2 e/ |5 W; Y
文章编号:1001-4322(2011)07-1882-03
8 ]; P$ a: s0 H5 S( t' o5 ~& @1 _栏目信息:ICF与激光等离子体! E, R# g3 l V M2 `# A* K4 \
6 [8 D! t3 h5 a# i
相关文献:主题相关 全文快照 ! Y) M9 c( a9 `. Z
: G! _. D1 g! L! I
* ]' h; {" o$ {' S- b& PThird harmonic separator with high laser-induced damage thresholdWang Xiaodong,Zhang Jinlong,Ma Bin,Jiao Hongfei,Ding Tao,Cheng Xinbin,1.Institute of Precision Optical Engineering,Tongji University,Shanghai 200092,China;2.Shanghai Key Laboratory of Special Artificial Microstructure Materials and Technology,Shanghai 200092,China;3.School of Aerospace Engineering and Applied Mechanics,Tongji University,Shanghai 200092,ChinaAbstract:Using electron beam evaporation,a 355 nm separator was designed by depositiing SiO2 and HfO2 alternatively.The coating has a reflectivity of larger than 99% at 355 nm through optimization and a transmittance larger than 99% at 532 nm and 1 064 nm.It has good electric-field distribution.The spectra of the fabricated coating is close to the designed one.The laser-induced damage threshold of the coating is 5.1 J/cm2.Morphology of laser-induced damage of the coating was characterized by differential interference contrast microscope.[著者文摘]
1 y" X4 u# g# C) a
$ e+ `3 j3 |0 H1 j G) |& c4 FKey words:third harmonic separator; electron beam evaporation; laser-induced damaged threshold; thin film0 w% ]7 t% o6 _7 g
6 ?: b# P" l* Z) J ?* }; u& \: Q4 `/ G2 C4 o [0 H
. C' F( w- q6 Y9 a5 H% j |
