查看: 930|回复: 0
制作P910满屏显示画面主题..
发表于 2006-6-3 03:14:50 | 显示全部楼层 |阅读模式
<span id="lblCnt" class="TD" style="color:Black;"></span>< class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2&#46;0"><FONT size=3>1<FONT face="Times New Roman">、</FONT>所需软件: <FONT face="Times New Roman">Sony EricssonThemesCreator_210&#46;exe</FONT> 汉化版 </FONT></P>1 `* q. k  y- m' n* h  Y
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT size=3><FONT face="Times New Roman">       2、</FONT>图片素材:相关图片 <FONT face="Times New Roman">5</FONT> 张,其规格用途如下,详见图 <FONT face="Times New Roman">1</FONT> 图 <FONT face="Times New Roman">2</FONT> 示意 </FONT></P>
1 B7 a$ k# {7 r6 R5 N6 E< class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT size=3><FONT face="Times New Roman">    </FONT>① 、打开键盘盖时图片一:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">26</FONT> 像素),图片格式为 <FONT face="Times New Roman">bmp</FONT> </FONT></P>
5 a6 K4 _( T% [) h, l0 q0 e< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman">    </FONT>② 、打开键盘盖时图片二:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">24</FONT> 像素),图片格式为 <FONT face="Times New Roman">bmp</FONT> </FONT></P>
% T/ V8 H/ B+ Z0 o8 Z% f5 Z< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman">    </FONT>③ 、打开键盘盖时图片三:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">256</FONT> 像素),图片格式为 <FONT face="Times New Roman">jpg</FONT> </FONT></P>, u8 O3 s) x+ F7 L0 Q% V* L
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman">    </FONT>④ 、合上键盘盖时图片四:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">32</FONT> 像素),图片格式为 <FONT face="Times New Roman">bmp</FONT> </FONT></P>
- v$ Q5 e& R4 `7 t( ?< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman">    </FONT>⑤ 、合上键盘盖时图片五:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">190</FONT> 像素),图片格式为 <FONT face="Times New Roman">jpg</FONT> </FONT></P>3 |+ N- N7 \! I' v5 {- s
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3> </FONT></P>
2 f- f* g5 @* o< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3>需要说明的是: </FONT></P>
: S" Z/ a8 J) `2 c# o; O$ W< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3>一、图片 ① ② ③ 由一张(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">306</FONT> 像素)的图片分割而成 </FONT></P>
4 \/ O0 L/ Q+ H1 F+ V( X$ m<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3> </FONT></P>
% a  ^9 z4 y, Y  n$ N- f0 {<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3>二、图片 ④ ⑤ 由一张(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">222</FONT> 像素)的图片分割而成,但是其中有 <FONT face="Times New Roman">16</FONT> 像素的部分是重合的,不能简单的一分为二。</FONT></P>
0 ~2 V6 x( J' \7 r3 v; W: g# E<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3> </FONT></P>4 J8 m: k+ j5 X" v
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 21pt; TEXT-INDENT: -21pt; mso-char-indent-count: -2&#46;0"><FONT size=3>三、图片 ④ 虽然高为 <FONT face="Times New Roman">32</FONT> 像素,但是实际只显示上半部分的 <FONT face="Times New Roman">16</FONT> 像素,并同时出现在打开键盘盖时的屏幕最下方,而且该部分图像是默认的,不能替换。 </FONT></P>
0 w% ^7 h& N1 x+ z7 X<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 21pt; TEXT-INDENT: -21pt; mso-char-indent-count: -2&#46;0"><FONT size=3> </FONT></P>
3 ]+ M6 [' \. t  H% o: T& ]<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><FONT face="Times New Roman"> </FONT> 图 <FONT face="Times New Roman">1</FONT> :打开键盘盖时图片位置示意 </FONT></P>. R9 y$ P1 m& n5 i
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=382 alt="开盖&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/f408aeaa9b&#46;jpg" width=400 border=1></FONT></P>
0 ?( \7 M4 x; {7 ~7 g. k<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3></FONT></P>3 Q$ L$ {9 Z& {1 \' J
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3>图 2 :合上键盘盖时图片位置示意 </FONT></P>6 {) [) f* L! K  T3 E
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=249 alt="关盖&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/cc7235ae09&#46;jpg" width=400 border=1></FONT></P>5 @6 `8 w: g8 {) p# N5 y
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3> </FONT></P>
; m$ Y& n3 X* `2 C& y" k<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3></FONT></P>. ~5 g0 s% H; O
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT face="Times New Roman"><FONT size=3>      <FONT face=宋体>3、以上图片来源丰富,在网上随意搜索,用 ACDSee 和 Photoshop 等制图软件编辑一下即可。 </FONT></FONT></FONT></P>
0 f: ^' i( b% g<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT size=3> </FONT></P>: [8 w8 ]- d9 q
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT face="Times New Roman"><FONT face=宋体 size=3>   4、好了,下面就开始制作 </FONT></FONT></P>
  i, _8 N( X1 \* h<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT size=3> </FONT></P>; [3 ~& i- \9 H# B4 e. H
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT face="Times New Roman"><FONT face=宋体 size=3>   5、用主题制作工具 Sony EricssonThemesCreator_210&#46;exe 汉化版,打开一个 utz 格式的主题文件,进入工作界面,当然,不打开现有的主题文件,直接制作自己的主题也可以,这里只是为了节省输入其它主题相关文件(诸如环绕、掩饰、标题/文字色彩等等)的过程而采取的一种快捷方式而已&#46; </FONT></FONT></P><FONT face="Times New Roman"><FONT face=宋体>+ Q* U; p. C/ b7 y! ^
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=center><BR></FONT></FONT><FONT size=3><FONT face=宋体>图 </FONT><FONT face="Times New Roman">3</FONT><FONT face=宋体> : 主题制作工具工作界面 </FONT></FONT></P>
$ w3 p- e1 T! e: Z  m<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT face=宋体 size=3><IMG style="CURSOR: hand" onclick=oi(this); height=306 alt="制作界面1&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/ccb39728af&#46;jpg" width=400 border=1></FONT></P>
) ~) G+ M0 @: E3 a<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3> </FONT></P>
) q) n  r/ b+ l3 v& b# R<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=left><FONT size=3><FONT face="Times New Roman">      6、</FONT>在待 <FONT face="Times New Roman">[</FONT> 机选项栏 <FONT face="Times New Roman">]</FONT> 中,点击“移除”按钮,将现有图片删除</FONT></P>" ]( ?) ]+ J: u, B: a! [/ F- p
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=left><FONT size=3> </FONT></P>/ v: {" g) a, {
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=left><FONT size=3><FONT face="Times New Roman">      7、</FONT>点击“输入”按钮,将“合上键盘盖时图片五:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">190</FONT> 像素),图片格式为 <FONT face="Times New Roman">jpg</FONT> ”的图片贴上 </FONT></P>
6 t0 q( R0 C0 Z3 Y3 Q9 _: m<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=left><FONT size=3> </FONT></P>
9 u. d' j% T) o% g$ r3 \9 o<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=left><FONT size=3><FONT face="Times New Roman">      8、 </FONT>用同样的操作方法删除并更新 <FONT face="Times New Roman">[</FONT> 状态栏背景 <FONT face="Times New Roman">]</FONT> 的图片(图片四尺寸:宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">32</FONT> 像素图片格式为 <FONT face="Times New Roman">bmp</FONT> ) </FONT></P>. q1 c* ^, ^( E. p. ]
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT size=3> </FONT></P>& E1 O% K' n. b( w* k+ m
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3>图 <FONT face="Times New Roman">4</FONT> :更新图片 </FONT></P>
0 K# g1 u- C5 Z6 c<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=307 alt="制作界面&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/d456bd0fa5&#46;jpg" width=400 border=1></FONT></P>
) H4 C7 i' _( e- n9 a! f; J% v<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3> </FONT></P>
1 ~/ h5 K* ~+ ^) I<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=left><FONT size=3><FONT face="Times New Roman">      9、</FONT>根据自己的喜好,编辑相关栏目的文字、颜色、屏保、音乐等,满意后将该主题文件另外命名后保存。 </FONT></P>
  S' s5 {/ Z' J<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3>图 <FONT face="Times New Roman">5 </FONT></FONT></P>
% v. I3 o4 a  y* L( M1 Y<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=240 alt="制作界面4&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/39eeb3cd06&#46;jpg" width=400 border=1></FONT></P>  W. `3 W6 q3 c; A+ x5 c
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3> </FONT></P>: P, ]0 @! w2 t! C  x* I7 \
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3>图 <FONT face="Times New Roman">6 </FONT>实际显示效果 <FONT face="Times New Roman">1</FONT> </FONT></P>
! D. V; R# }, h0 ]: ?* X6 Y- D! }8 m<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=158 alt="4合1&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/3684f525e2&#46;jpg" width=400 border=1></FONT></P>
# Q; d8 A4 O/ X8 [+ E' x# Q) i, M<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3> </FONT></P>
" A6 o3 u- H0 L* z8 \  |) J<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3></FONT></P>
8 g3 @' W/ K( ^<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman">    用同样的方法,我们可以制作出各种风格的可以满屏幕显示的主题&#46;</FONT> </FONT></P>! ~9 i# ^/ l1 B: j5 K5 M
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3> </FONT></P>6 X+ ]/ @" }# W' ^4 |) B$ H+ I
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3>图 <FONT face="Times New Roman">7</FONT> 实际显示效果 <FONT face="Times New Roman">2</FONT> </FONT></P>
$ R: o5 V# V3 r% Q2 Q0 B2 [6 Y<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=307 alt="雪耶主题&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/fa400c5e7d&#46;jpg" width=400 border=1></FONT></P>. ]0 o% f3 h' z/ j, a# i5 y+ Z
+ _$ X7 ?2 b# M6 F1 R) E4 W<P><FONT size=3><FONT face="Times New Roman">    希望对各位P910机油有所帮助,快自己动手试吧!</FONT> </FONT></P></TD>
GMT, 2025-12-21 , Processed in 0.027409 second(s), 23 queries .
