查看: 757|回复: 0
577w/586w 刷机教程
发表于 2006-6-3 03:14:47 | 显示全部楼层 |阅读模式
<span id="lblCnt" class="TD" style="color:Black;"></span><FONT face=宋体 size=3>    1&#46; 用 USB 数据线将手机和电脑连接; <BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></FONT>
# T( ^' @, C; T2 O$ R< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>        2&#46; 下载刷机必备工具 </FONT><FONT face=宋体 size=3>SDA_ApplicationUnlock,regeditSTG, spvservices, ROMUpdateUtility<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></FONT></P>
) H# ~0 w  ^7 E0 l. g! Y< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>        3&#46; 把 regeditSTG 传到手机里(不能在卡上),在手机中打开 regeditSTG&#46;exe 修改注册表 : </FONT></P>
9 Z2 V( e% y9 Z, t+ j7 D  ]* ?& I: ^< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>   HKEY_LOCAL_MACHINE\Security\Policies\Policies\00001001 = 2 =&gt; 1 </FONT></P>' z6 }) X- K/ b: K
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>   </FONT><FONT face=宋体 size=3>HKEY_LOCAL_MACHINE\Security\Policies\Policies\00001005 = 16 =&gt; 40<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></FONT></P>9 X3 j7 t/ U4 C
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>        4&#46; 在电脑上运行 SDA_ApplicationUnlock&#46;exe&#46; 解锁,重启手机。 <BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></FONT></P>
7 v: J8 ?  m7 x" B: u  w< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>        5&#46; 刷 supercid : 打开 spvservices&#46;exe ,出现界面后点左边 CID Tool ( Alpha ) ,等出现“ Set CID = <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comffice:smarttags" /><st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="11111111" UnitName="”">11111111 ” </st1:chmetcnv>按钮 则点击, 看 到 ”ALL OK” 就成功了。刷 supercid 是为了防止刷坏手机。 <BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></FONT></P>& A* E3 B- _4 T+ C( |
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>        6&#46; 刷机开始: </FONT></P>0 x! c  |; S- K' k# j
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face=宋体><?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:p> </o:p> </FONT></FONT></P>  ~6 @! R) c  {5 r- _
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21&#46;75pt"><FONT face=宋体 size=3>(1)首先将要刷的 ROM 放到刷机工具 ROMUpdateUtility 的同一个文件夹下面。启动 ROMUpdateUtility&#46;exe 出现界面,将空白的打勾,点 Next </FONT></P>: f3 j* a( E0 k# d) m: D
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21&#46;75pt"><FONT size=3><FONT face=宋体><o:p> </o:p> </FONT></FONT></P>
" m& Z% E1 d( V, ^( ?- z1 e' y* M<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21&#46;75pt"><FONT size=3><FONT face=宋体><B style="mso-bidi-font-weight: normal">注意 </B>:你的电脑要关闭休眠功能,并且手机电池的电力大于百分之 50 的比例。 <BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></FONT></FONT></P>6 E$ r3 N( e) o
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>       (2)将空白处打勾,按 Next 进入下一个界面,接着开始检查 smartphone 资料。 <BR><BR>       (3)检查完成后显示你手机的资料,接着,按 update 继续下一步。 <BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></FONT></P>; H3 x% B$ t6 R3 q  [
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>       (4)接下来的界面显示的是你要刷的 ROM 的版本。接着按 Next 继续。 <BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></FONT></P>
( U2 t9 ]9 |: j: P<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>       (5)开始更新 rom ,大约需要 10 分钟的时间,按 Next 继续下一步。<BR style="mso-special-character: line-break"></FONT></P>% v& H7 L9 ]+ R9 {
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>       (6)电脑和手机上都能看到进度,百分之百后还要等 2 分钟左右!<BR style="mso-special-character: line-break"></FONT></P>
& O% m9 W( {  C" u* B; {8 p. {- U<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21&#46;75pt"><FONT face=宋体 size=3>(7)手机自动重启,然后按提示还得在重启一次就完成了 </FONT></P>1 W' k  @4 j1 U6 h$ X
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face=宋体><o:p> </o:p> </FONT></FONT></P># `+ C' |: q' Y( j  C
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>    再补充下:先刷成 supercid 以后刷的只是 os 部分,就刷出问题了不会损坏手机。 </FONT></P>5 S" x% o4 S* |1 I* J
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3> </FONT></P>
! }- _# d7 u) r, x: `<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT face=宋体 size=3>    <B style="mso-bidi-font-weight: normal">请务必注意 </B>你的手机要电量充足,刷机的过程中不要断电,不要拔 usb 数据线,最好不要运行其他的任何程序。还有以前教程是针对 nbf 格式的 rom ,其他的格式不通用。 </FONT></P>/ b+ T, o2 t& L, U3 E& _. w
<P><FONT face=宋体 size=3>    刷机有风险,请仔细考虑后再做决定!</FONT></P></TD>
GMT, 2025-10-14 , Processed in 0.030744 second(s), 23 queries .
