查看: 1338|回复: 2
[求助] targets cone angle 是怎么使用的?
发表于 2011-7-8 12:43:40 | 显示全部楼层 |阅读模式
哪位大哥 能和我说下
6 G# i! }3 q. \* A" A8 ]4 v4 OTFCalc targets cone angle是怎么使用的6 A" R8 M% b5 r' n
谢谢
1 v# }2 E. q0 x/ N2 L9 K# a# Y3 K, u% C. _$ Q$ v* u
发表于 2011-7-8 13:16:51 | 显示全部楼层
3 l' J; H$ l& Z9 }2 L% }5 J1 B) R) n1 e( a% z; b3 r- k
给你个官方的例子:9 L4 d2 a* U, j7 n
$ e) b# a" x, Q2 I+ u/ Y" H
0 z! `! _. Z% w) b2 nBroadband AR for a Cone of Light
$ B- O  a  P! J$ i1 `Here we consider a coating on glass that reflects only 0.5% of a cone of light for a range of wavelengths from 420 to 680 nm. The cone axis is normal to the glass. The cone has an F-number of 0.778, which means the half-angle is 40 degrees. An uncoated glass surface reflects 4.4% of this cone of light. We use a feature new to version 3.5: cone-angle targets. As optimization targets we use 5 a2 L: M% `6 h* q; ^& M, l1 m
R < 0.5% for wavelengths 420, 425, 430,..., 680 and for a 40-degree cone
  e* @5 |% ]* C9 k; M. X
% d9 N- n; [/ |4 B5 h  m! YIn TFCalc, these targets are easy to enter by using the "Generate Cone Targets" command on the Options menu of the "Targets - Cone Angle" window. We use TFCalc's needle/tunneling optimization to design the coating from "scratch". That is, we begin the design process with a single thin layer of TiO2 and allow TFCalc to increase the thickness and number of layers in the design. TFCalc finds a 6-layer design in a few minutes. The performance of this design is shown below. The little circles indicate the optimization targets.
$ G" Y& C1 p7 v1 ~1 a, N& A  `7 ~2 a& Y/ I* k: H5 |
; w7 {* ?, l7 Z6 q. M Here is the design, starting with the layer closest to glass, and with thicknesses given in nm: 4 I& O- |2 I5 V% x5 N
TIO2          11.04( f: ^5 g9 ]& v, V- J
SIO2          44.43; D  W4 ]3 V8 o6 _& q& u) m  {- t$ M
TIO2          34.99
  a, |9 c/ ?6 D/ P( aSIO2          28.25) x6 u. ?6 E; h$ b1 Q9 g* l7 r9 `0 b
TIO2          30.46& e: n; `: }& S" N% |, U' g3 g
SIO2         104.92
& t0 s+ y9 a: |" F3 W3 q4 F
7 P2 r  `* g+ W
2
发表于 2012-9-7 02:35:36 | 显示全部楼层
多角度的?还是圆锥角啊?
GMT, 2026-5-2 , Processed in 0.029830 second(s), 24 queries .
