查看: 645|回复: 2
[转贴] The Design of Multilayer Optical Coatings Using Convex Optimization
发表于 2011-7-4 12:01:10 | 显示全部楼层 |阅读模式
" F# s1 Z8 K" q9 ~2 xMohamed A. Swillam, Student Member, IEEE, Mohamed H. Bakr, Member, IEEE,
2 F- Y) i1 Y. F' qand Xun Li, Senior Member, IEEE
3 w; h" s5 P9 r# F' [Abstract—For the first time, convex optimization is applied to+ h. U# ?5 q& S# A1 [
the design of multilayer optical coatings. We present two different. `. k6 @$ [6 Y+ v; S( X
approaches to approximate the design problem as a convex optimization& i  `/ U2 J" q( K, R! z9 K
problem. This problem is then efficiently solved using interior' K4 U9 |: f% }/ f$ N
pointmethods. Our formulation is fast and flexible, allowing5 ?1 [; k* ?7 \
the designer to add any number of constraints. The results show
* S3 h1 y2 U, e! K. J8 F* D9 ythat the used approximation is tight and has a good match with
" L' x- ]3 G2 Z9 L2 v& J# sthe exact solution.
+ m- Z% u9 K  S! ]6 G, t6 a2 bIndex Terms—Antireflection (AR) coatings designs, convex optimization,
6 A9 A6 F, `; z. q) T; {* J8 dinterior point method (IPM), linear programming6 s' v/ g5 H1 M" w/ F4 j" Y" L
(LP), multilayer optical coatings, optical filter designmethodology,
$ j# q6 j8 X) `- D6 h; x9 C" D- Uthin films.0 l+ v7 a  e4 G, r1 \
143
QQ
发表于 2011-7-4 16:25:28 | 显示全部楼层
謝謝樓主的好資料0 C9 f$ p' O9 s8 }) \& O# v# a
36
发表于 2011-7-5 12:38:46 | 显示全部楼层
谢谢楼主好资料
GMT, 2026-6-10 , Processed in 0.035332 second(s), 26 queries .
