查看: 642|回复: 2
[转贴] 基于紫外-可见透过谱的薄膜厚度计算研究
发表于 2011-6-28 13:48:05 | 显示全部楼层 |阅读模式
基于紫外-可见透过谱的薄膜厚度计算研究张海波[1] 康建波[2] 孙辉[2] 杨定宇[2] 朱兴华[2][1]成都信息工程学院网络工程学院,四川成都610225 [2]成都信息工程学院光电技术学院,四川成都610225摘 要:测试和控制薄膜的厚度是制备高质量薄膜材料的重要步骤之一。本文根据光谱透过率波动曲线与薄膜厚度间的内在联系,基于曲线拟合方法设计开发了一款计算软件,该程序能读取测试光谱数据并自动计算出薄膜厚度和折射率,程序计算结果与台阶仪测试结果吻合较好,证明本文所开发的软件是正确有效的。[著者文摘]( B% I+ P3 w) p# ]$ n
6 ?% E- }+ ?6 X# ~6 o关键词:紫外-可见透过谱 薄膜厚度 曲线拟合 程序设计
3 R0 L2 H6 r2 A& |
8 v8 i) f4 V; W& J分类号: TN304[著者标引]
/ y6 {8 S0 P3 C5 l; \文献标识码:A
* z" t6 G$ j" D+ Q- _文章编号:1673-159X(2010)06-0070-039 T1 Q2 [( Q0 g' S+ E% b
栏目信息:材料科学
. L7 z$ I7 C' p7 w* K# G3 H* j
) }: M7 T/ d8 W- c相关文献:主题相关 全文快照   - t3 j$ F) _0 m( G- L
- l! K' b: ~/ h/ C3 L. G& s7 c: ^/ g1 R7 s7 b
Research on the Calculation of Film Thickness Based on UV-visible SpectrumZHANG Hai-bo,KANG Jian-bo,SUN Hui,YANG Ding-yu,ZHU Xing-hua1.School of Network Engineering,Chengdu University of Information Technology,Chengdu 610225 China;2.School of Optoelectronic Technology,Chengdu University of Information Technology,Chengdu 610225 ChinaAbstract:The measurement and control of thickness are important steps in the deposition of high-quality films.At present,the film thickness obtained by UV-visible spectra is widely used as a non-invasive method.According to the inherent relationship between the interference fluctuation of UV-Vis transmission and the film thickness,a kind of software was designed based on certain algorithm and fitting method,which can read data of UV-Vis spectra then automatically calculate and output film thickness and refractive index.It is found that the procedure result is in good agreement with the measurement of surface profile,showing considerable reliability.[著者文摘]
6 v  H5 `% }4 f; n' y6 y# d4 t* q* C9 q& P
Key words:UV-visible spectrum; film thickness; curve fitting; program designing4 G& F! J% k: W  o* O7 P
# A" p& [# G3 _- T; h
7 A! P$ J$ c. ^1 w$ r! u1 J# u& g! `
/ g; w/ p: o: ?, A% t7 z$ ]. b8 y% j! y1 [6 J
1 c: }2 F% A1 h- D, }2 R, |9 j' D, @" G) ?  y6 b3 b
1
发表于 2011-6-28 14:09:14 | 显示全部楼层
看看,谢谢啦!
143
QQ
发表于 2011-6-28 14:10:07 | 显示全部楼层
謝謝樓主的資料
& }$ T. R) Z2 T; f
GMT, 2026-6-10 , Processed in 0.025496 second(s), 26 queries .
