查看: 1432|回复: 0
[转贴] X-ray Reflectivity Evaluation for the Density of
发表于 2011-6-28 13:45:26 | 显示全部楼层 |阅读模式
X-ray Reflectivity Evaluation for the Density of Au Thin Film Deposited on SiliconZHANG Yan-ping[1] CHANG Hong-wei[1] DU Shu-bin[1] Kenji Sakurai[2][1]不详 [2]National Institute for Materials Science, Tsukuba, Ibaraki 305-0044, Japan摘 要:
- v' c  i5 G9 h
" N3 _! J+ {0 }# m关键词:极低密度 Au薄膜 X射线 评价 反射 沉积 硅 金薄膜
* X4 b* ?! d+ o  Q$ M1 `5 [4 v
1 s. E, {7 u/ f7 Z5 X分类号: O434.1 TQ325.12[机标]0 a- s9 E7 S& s2 [/ f
文献标识码:
6 @- [$ _! A9 L6 g+ k1 M% c文章编号:1 h! U, T+ o7 i- i& `
栏目信息:FUNDAMENTAL AND APPLIED FUNDAMENTAL RESEARCH6 ]; U( X8 Z* a) Y0 j
* K' S' ^4 I! ^# l" q5 h
相关文献:主题相关 全文快照
) a/ l2 h8 X% g' x
2 B% C- O2 R  J1 J+ v0 g( D$ ?; Y2 Z4 [0 k' ]- m- S  N
X-ray Reflectivity Evaluation for the Density of Au Thin Film Deposited on SiliconAbstract:In present work, we will reports puttered gold thin film that sometimes has extremely low density (6.1 g/cm^3, 32% to the bulk value 19.3 g/cm^3 found in the literature) based on XRR studies, low-density sample is thick and the thickness is about 3.29 times to that of high-density sample, XRR measurements see Fig. 1.[第一段]" C5 \( w2 H/ s! I" F( _( ?& u
4 l& b0 E( z( B8 IKey words:4 _6 `& Y2 I* A, `
8 ]6 T( I: U7 |, [
$ @" n" P$ n. ~$ n$ a9 I
! d/ k8 }3 ]/ B( ?. e' _" t: Z, P% V& {
/ Q: L# S4 c& h4 S# [/ v. b+ W" R$ N! O' i
GMT, 2026-11-24 , Processed in 0.020055 second(s), 25 queries .
