查看: 821|回复: 0
制作P910满屏显示画面主题..
发表于 2006-5-28 19:31:07 | 显示全部楼层 |阅读模式
<span id="lblCnt" class="TD" style="color:Black;"></span>< class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2&#46;0"><FONT size=3>1<FONT face="Times New Roman">、</FONT>所需软件: <FONT face="Times New Roman">Sony EricssonThemesCreator_210&#46;exe</FONT> 汉化版 </FONT></P>8 R3 x4 }7 t8 F! Y( w( g0 x
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT size=3><FONT face="Times New Roman">       2、</FONT>图片素材:相关图片 <FONT face="Times New Roman">5</FONT> 张,其规格用途如下,详见图 <FONT face="Times New Roman">1</FONT> 图 <FONT face="Times New Roman">2</FONT> 示意 </FONT></P>
9 G+ j" r' X; r0 a( f4 @1 S< class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT size=3><FONT face="Times New Roman">    </FONT>① 、打开键盘盖时图片一:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">26</FONT> 像素),图片格式为 <FONT face="Times New Roman">bmp</FONT> </FONT></P>
* w% O: U( p/ M4 C< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman">    </FONT>② 、打开键盘盖时图片二:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">24</FONT> 像素),图片格式为 <FONT face="Times New Roman">bmp</FONT> </FONT></P>  D2 v! A+ c# Q( I- {" r( z3 @
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman">    </FONT>③ 、打开键盘盖时图片三:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">256</FONT> 像素),图片格式为 <FONT face="Times New Roman">jpg</FONT> </FONT></P>
+ T" x( H% b* O4 t/ W1 B< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman">    </FONT>④ 、合上键盘盖时图片四:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">32</FONT> 像素),图片格式为 <FONT face="Times New Roman">bmp</FONT> </FONT></P>
0 m% C4 l) z# @# l< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman">    </FONT>⑤ 、合上键盘盖时图片五:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">190</FONT> 像素),图片格式为 <FONT face="Times New Roman">jpg</FONT> </FONT></P>
1 K9 N2 ?) \+ k/ v+ l- |) O< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3> </FONT></P>7 N& P% m* S3 W& B
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3>需要说明的是: </FONT></P>
# ]3 w7 N& B7 T" a# w3 v$ N< class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3>一、图片 ① ② ③ 由一张(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">306</FONT> 像素)的图片分割而成 </FONT></P>
1 h( n  p4 \  B0 ~" F<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3> </FONT></P>8 X: T) l7 {0 {7 m0 Y+ @
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3>二、图片 ④ ⑤ 由一张(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">222</FONT> 像素)的图片分割而成,但是其中有 <FONT face="Times New Roman">16</FONT> 像素的部分是重合的,不能简单的一分为二。</FONT></P>
2 Q: ], O/ i1 F( P  V; f1 \3 J<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3> </FONT></P>
2 P2 J) s9 }/ ~3 L<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 21pt; TEXT-INDENT: -21pt; mso-char-indent-count: -2&#46;0"><FONT size=3>三、图片 ④ 虽然高为 <FONT face="Times New Roman">32</FONT> 像素,但是实际只显示上半部分的 <FONT face="Times New Roman">16</FONT> 像素,并同时出现在打开键盘盖时的屏幕最下方,而且该部分图像是默认的,不能替换。 </FONT></P># K! S4 V4 r6 R: x( E5 g7 s+ U+ M
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 21pt; TEXT-INDENT: -21pt; mso-char-indent-count: -2&#46;0"><FONT size=3> </FONT></P>9 F6 M( \0 H1 g3 T% T4 r. C
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><FONT face="Times New Roman"> </FONT> 图 <FONT face="Times New Roman">1</FONT> :打开键盘盖时图片位置示意 </FONT></P>
; y2 B# c, U6 L# o: e! b( P<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=382 alt="开盖&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/f408aeaa9b&#46;jpg" width=400 border=1></FONT></P>, f1 f( L: t) M$ z/ r! y( q
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3></FONT></P>1 J: a* G* P+ [! V& v) }0 l* ]
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3>图 2 :合上键盘盖时图片位置示意 </FONT></P>
2 r  w9 n2 s. i. N<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=249 alt="关盖&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/cc7235ae09&#46;jpg" width=400 border=1></FONT></P>! p4 S4 w6 t6 O7 B% I8 n8 O7 U
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3> </FONT></P>2 c% H5 @" R/ a! \, h
# u% G( |- ~6 h* v<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT face="Times New Roman"><FONT size=3>      <FONT face=宋体>3、以上图片来源丰富,在网上随意搜索,用 ACDSee 和 Photoshop 等制图软件编辑一下即可。 </FONT></FONT></FONT></P>  V. L6 D; T1 y7 y$ q/ L' j
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT size=3> </FONT></P>
$ u0 U; k9 d: ]5 e7 C" v( p<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT face="Times New Roman"><FONT face=宋体 size=3>   4、好了,下面就开始制作 </FONT></FONT></P>
7 o) e) |, \! {/ u6 n; k<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT size=3> </FONT></P>
' l/ O* ^' z+ X, ?; f, P<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt"><FONT face="Times New Roman"><FONT face=宋体 size=3>   5、用主题制作工具 Sony EricssonThemesCreator_210&#46;exe 汉化版,打开一个 utz 格式的主题文件,进入工作界面,当然,不打开现有的主题文件,直接制作自己的主题也可以,这里只是为了节省输入其它主题相关文件(诸如环绕、掩饰、标题/文字色彩等等)的过程而采取的一种快捷方式而已&#46; </FONT></FONT></P><FONT face="Times New Roman"><FONT face=宋体>* e$ x; v1 C! \
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=center><BR></FONT></FONT><FONT size=3><FONT face=宋体>图 </FONT><FONT face="Times New Roman">3</FONT><FONT face=宋体> : 主题制作工具工作界面 </FONT></FONT></P>( [4 s' P$ G1 L+ k+ m5 G
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT face=宋体 size=3><IMG style="CURSOR: hand" onclick=oi(this); height=306 alt="制作界面1&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/ccb39728af&#46;jpg" width=400 border=1></FONT></P>% y0 A' O1 \+ g
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3> </FONT></P># P, w1 {8 g- x+ c& {; S  n* O9 S; i7 J
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=left><FONT size=3><FONT face="Times New Roman">      6、</FONT>在待 <FONT face="Times New Roman">[</FONT> 机选项栏 <FONT face="Times New Roman">]</FONT> 中,点击“移除”按钮,将现有图片删除</FONT></P>  [! @! b) L3 c; H" [
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=left><FONT size=3> </FONT></P>
1 T. r7 T0 F2 s, Y) u/ m: ^* j5 y<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=left><FONT size=3><FONT face="Times New Roman">      7、</FONT>点击“输入”按钮,将“合上键盘盖时图片五:尺寸(宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">190</FONT> 像素),图片格式为 <FONT face="Times New Roman">jpg</FONT> ”的图片贴上 </FONT></P>0 c- @: l7 D7 _. Z% S* p7 F( _
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=left><FONT size=3> </FONT></P>/ X8 v$ C- h! x- x! g1 u
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18&#46;0pt" align=left><FONT size=3><FONT face="Times New Roman">      8、 </FONT>用同样的操作方法删除并更新 <FONT face="Times New Roman">[</FONT> 状态栏背景 <FONT face="Times New Roman">]</FONT> 的图片(图片四尺寸:宽 <FONT face="Times New Roman">208</FONT> ×高 <FONT face="Times New Roman">32</FONT> 像素图片格式为 <FONT face="Times New Roman">bmp</FONT> ) </FONT></P>& B: ]. T7 X  o2 h
0 q$ H& Y+ n" @; H7 C+ ?) Z% |7 g<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3>图 <FONT face="Times New Roman">4</FONT> :更新图片 </FONT></P>* {1 d+ ~$ `9 x4 K$ \
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=307 alt="制作界面&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/d456bd0fa5&#46;jpg" width=400 border=1></FONT></P>, R8 X4 v0 r! Q, m& m* \
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3> </FONT></P>5 Y4 l; _; X4 K1 F6 o2 F3 v
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=left><FONT size=3><FONT face="Times New Roman">      9、</FONT>根据自己的喜好,编辑相关栏目的文字、颜色、屏保、音乐等,满意后将该主题文件另外命名后保存。 </FONT></P>
. i. }5 F4 ~6 Z2 @<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3>图 <FONT face="Times New Roman">5 </FONT></FONT></P>+ q8 N" M4 J8 t9 D* V, q
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=240 alt="制作界面4&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/39eeb3cd06&#46;jpg" width=400 border=1></FONT></P>! a1 @$ G5 ?8 ^4 A' b; h
+ k) v# L( C3 N5 v- S<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3>图 <FONT face="Times New Roman">6 </FONT>实际显示效果 <FONT face="Times New Roman">1</FONT> </FONT></P>
" M5 m# l2 T8 W! m4 O% f<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=158 alt="4合1&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/3684f525e2&#46;jpg" width=400 border=1></FONT></P>! I' G: u8 @9 ^
! y' ?8 F, M$ v. Y' _8 w' o<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3></FONT></P>0 I) L: i2 v5 z9 t! T% w- O% d
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman">    用同样的方法,我们可以制作出各种风格的可以满屏幕显示的主题&#46;</FONT> </FONT></P>
2 G) g. D7 L# @$ m% V<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3> </FONT></P>
, v7 \: \9 j: ~" m9 Q" E1 ?. g# g<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3>图 <FONT face="Times New Roman">7</FONT> 实际显示效果 <FONT face="Times New Roman">2</FONT> </FONT></P>
, t' N0 Y' H5 X( C, r<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt" align=center><FONT size=3><IMG style="CURSOR: hand" onclick=oi(this); height=307 alt="雪耶主题&#46;jpg&#13;&#10;按此在新窗口浏览图片!" src="http://bible&#46;younet&#46;com/images/2006/05/23/fa400c5e7d&#46;jpg" width=400 border=1></FONT></P>
1 ?& @/ u4 b1 U: u/ X9 y+ x  ?  R<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3></FONT></P>
; G( c6 M; H1 s) H  B6 A6 [<P><FONT size=3><FONT face="Times New Roman">    希望对各位P910机油有所帮助,快自己动手试吧!</FONT> </FONT></P></TD>
GMT, 2025-12-20 , Processed in 0.026739 second(s), 23 queries .
