查看: 819|回复: 1
[转贴] 基于遗传退火算法的多层薄膜厚度测量
发表于 2010-8-25 04:07:17 | 显示全部楼层 |阅读模式
基于遗传退火算法的多层薄膜厚度测量, T" z* A) O8 m( s4 i1 a9 ~
楚栋 宫兴致 程梁 余飞鸿浙江大学光电信息工程学系,杭州310027摘 要:根据薄膜光学计算理论和最优化理论,本文提出了一种测量多层薄膜厚度的新的全局优化算法。首先利用遗传的种群性去寻找多个局部极值,然后将较优和较差的种群按一定概率接收并作为模拟退火的初值进行搜索。最后结合共轭梯度算法来提高收敛速度,使整体搜索效率进一步提高。这种遗传退火算法有效地提高了算法的稳定性,减少了算法对膜厚搜索范围的限制。文章最后以3层和4层光学薄膜为例,利用该算法在10nm至5pm的大范围内搜索,所取得的结果,其测量误差小于1%。[著者文摘]* `* e8 F. @/ o. M
6 S! W1 J7 |/ O# `0 {5 N
关键词:多层薄膜测量 遗传退火算法 共轭梯度 光学薄膜7 t! L, m, M4 a( {* }$ w* n  n
分类号: O484.5[著者标引]文献标识码:A文章编号:1003-501X(2010)02-0045-05栏目信息:薄膜光学
* A- g9 ~) a8 L6 \7 X& G相关文献:主题相关 全文快照   4 j) ?+ \, p1 e8 c/ X
/ n4 h( Y) e8 j% D
Multilayer Film Thickness Measurement Based on Genetic Simulated Annealing AlgorithmCHU Dong, GONGXing-zhi, CHENG Liang, YU Fei-hong Optical Engineering Department, Zhejiang University, Hangzhou 310027, China Abstract:According to the theories of thin film calculation and optimization, a new global optimization method for multilayer film thickness calculation is presented. Firstly, a new group of local optimums is found out through genetic and mutation operation. Then, the solutions are accepted at a certain probability and will be calculated respectively in Adapted Simulated Annealing (ASA) process as the initial solutions. At last, conjugate gradient algorithm is utilized to search accurately and quickly. This genetic simulated annealing algorithm can effectively enhance the robustness of the algorithm and reduce the limitation of the searching area. The experimental results show that the proposed algorithm can calculate the thickness of 3-layer and 4-layer thin film within the range of 10 nm-5μm and less than 1% calculation error.[著者文摘]  M6 U9 g# T$ H6 L9 g
7 Q- k6 e7 N5 ]0 N9 ^" Q" {! VKey words:multilayer film measurement; genetic simulated annealing algorithm; conjugate gradient; optical thin films
1
QQ
发表于 2010-8-25 21:57:24 | 显示全部楼层
谢谢楼主分享
GMT, 2026-6-11 , Processed in 0.813231 second(s), 26 queries .
