商品货号:ECS001116 : l9 H# h. N$ h. j0 b
商品品牌:FJW
2 P5 D- T+ S+ J
8 V& g+ O" i2 H9 [# q' ` 4 z! o* R) x3 R5 j7 V" v$ n, Y5 X
& A- h1 m& d" s# @9 J) o
瀚宇(香港)科技有限公司代理产品
& d3 Q) G D$ G% `
# `& Z: U5 v- e& D1 I% R瀚宇(香港)科技有限公司除了自主研发拥有独立知识产权的高新技术产品之外,还代理引进国外先进仪器设备用于科研和生产,公司产品涵盖了各种激光器产品、光电产品、光机电产品、监测仪器仪表、材料分析仪器等。
) w* `+ o% v6 n( @5 x+ ^
L: M; n0 |9 H. D) V/ W" V8 b详情请登录:h ttp://ww w.hisky-hk.com d: t* b7 `; p5 ?) d7 @2 K
% J/ ]2 w: _ lField of View : 40°
. G/ ^0 b- Q; @& [7 J3 qMagnification: ~ 1:1
Q g, |# E& Z! v3 ^$ e. v( wSpectral Sensitivity : 350-1550nm
* e$ b- o. s0 U$ ^- y7 r! z) bLens: Custom Infragon 25mm, ƒ/1.0 ( q1 x' d* w4 V% @* E
Standard Focal Range : 100mm, (4") to infinity ( S Z# u8 j- D8 C, d3 Q
Regions Displayed: Near UV, Visible, Near-IR
" i# y2 G% \7 s+ w2 _* xPeak Sensitivity : 800nm 5 G4 V) G3 T0 v- W4 D: j8 Q, m
Resolution 70 Lines/mm, minimum
. Z7 `$ D& T8 {) N7 M- sDisplay: P20 Phosphor . r |5 x( C3 B; [( E
Power: (1) "C" cell
4 S J8 O+ j3 a' M& ?5 e& t1 ?1 K2 bBattery Life : >250-hours int.,100-hours contin. : A! J9 F D6 L- [
Sensitivity Test : See 1550nm, 350 µW LED @ 8-ft.
% u2 r+ k1 b; Z" ^& t1 I0 O' ~& {8 ZOperating Temperature -32° to 46°C, (-25 to 115°F) 4 Q7 }2 Z4 g! y" r
! [4 T, p S! G$ {/ @
8 L5 j8 X! A6 w, C- M# R. z# A- Q) dPrinter Friendly Version
" d% N5 o7 o- r$ T& K) ` X: s& }4 C' ^The FIND-R-SCOPE 84499A-5 is a self-contained, hand-held infrared viewer with an extended spectral sensitivity of 350-1550 nm.- w) q, W8 W! G
/ B, x* ?6 \) K) F6 h3 iExtended Sensitivity 5 [" p1 K$ c# v; |8 f: t* l% r
Self-Contained % W2 J/ \, r5 e: f0 R) h; h
UL Approved 3 g5 ^( a( O. U
High-Resolution
3 z6 f1 D6 R1 t% \( a& _! d0 ]Custom f/1.0 Infragon Lens
: a s! a0 \$ p" C. WUser Adjustable Eyepiece
\" t8 q1 E5 s0 oStandard Tripod Mount
+ C, t* S0 V* {6 G' Z6 `0 l( } Accepts Optional Filters
# z7 T1 G# j4 ^6 ^$ IAccepts Close-up Lenses
2 H- C4 h1 a9 D9 h4 N& eAccepts Optional Iris % e5 a) ?6 }2 K& _3 Y. U2 A
Accepts Optional CCD Mt. 8 C& g2 ^$ w. U; I
Includes Battery
: r' d3 {% Y( \, UIncludes Hard Side Case 0 r0 y3 h9 `( E
18-Month Limited Warranty
4 ^' ^$ m5 u# [8 h( ~7 p+ m 5 p' \9 B. ]. F
$ v! `# m- s1 i( \
& V9 Z# c! u) W; H4 Z) n* n
7 t2 t1 Q3 C# hThe FIND-R-SCOPE® 84499A-5 is a self-contained, hand-held infrared viewer operating in the near-infrared region of the spectrum. A high-resolution image converter tube, and high voltage power supply combine with proprietary Infragon objective lens and other precision optics to permit a clear view of objects or images which can not otherwise be seen by the naked eye." Y4 w9 s0 \# T% Z* o
) ]3 @5 X. O0 S5 S' N9 p
The FIND-R-SCOPE® has a wide variety of applications in many different industries. These applications are further expanded by taking advantage of the available accessories. (See right border for most popular accessories for this unit.) The optional close-up lens allows for viewing within 2" to align and verify fiber optic sources. The infrared filters increase the signal-to-noise ratio by blocking visible light while inspecting infrared emitting diodes, aligning laser systems and examining art and other historic or legal documents.1 C8 d; ?! o$ `& T& z# k
H' G$ [, A( v; R B8 S" n/ TOther applications include low light surveillance, biological research, electrical maintenance, hot-spot detection, clinical medicine, and viewing in photographic darkrooms. |
