查看: 1526|回复: 0
[转贴] Nonpolarizing Beamsplitter for OIC Contest
发表于 2010-6-17 02:01:36 | 显示全部楼层 |阅读模式
[size=+3]Nonpolarizing Beamsplitter for OIC Contest
2 O: E7 u9 L' X  Y: e# S# h[ Contents ] [ Index ] [ Home ] 3 B7 U9 p6 Z! X& n! X' Z( S
Every three years the OSA (Optical Society of America) holds a meeting called OIC (Optical Interference Coatings). As part of that meeting, there is always a design contest. The 2007 meeting has two design problems, the second of which is discussed here. The first problem is a Triple Bandpass Filter.
! K: E/ l: c4 p& c8 K1 O: TThe challenge is to design a 45° beamsplitter on a glass (index 1.52) substrate. The incident and exit mediums are air. Only the front side of the substrate needs a coating; we can assume the back side has a perfect AR coating. For a wavelength range as wide as possible, and centered at 550 nm, the beamsplitter design has the following performance requirements: - d! k8 J2 w5 i/ ?& {( l2 m4 |
| Rs - Rp | ≤ 2% ; ?7 a$ [7 Z8 l( U
40% ≤ Rs ≤ 60% & w7 H# s, X4 G6 i# Q2 O0 ]; L( ^) ?
40% ≤ Rp ≤ 60% ' h! ]( P( e( z( \+ W& p
| δRs - δRp | ≤ 1° (difference of p and s reflected phase, Abeles convention)
3 N* z, z( o+ z8 c9 R' \| δTs - δTp | ≤ 1° (difference of p and s transmitted phase) The coating design may use a maximum of three materials from the following list of seven indices: 1.38, 1.45, 1.65, 1.8, 2.05, 2.2, and 2.35. The materials are assumed to be dielectric and non-dispersive. There is no limit on the number of layers. However, layers are required to be at least 5 nm thick. The design is to be evaluated every 0.001 nm to ensure that all requirements are met. The winning design is the one that meets the requirements for the widest wavelength range centered at 550 nm. , ?8 L& ?( u  g& L
The above requirements can be translated into seven continuous optimization targets. We give the first five targets more weight than the last two phase targets because it is best to meet the reflectance targets before worrying about phase. An important decision is the selection of the three coating materials. There are a total of 35 combinations of seven materials. Experience suggests that the three indices should be as widely separated as possible. Three good possibilities are the sets (1.38, 1.65, 2.35), (1.38, 1.8, 2.35), and (1.38, 1.65, 2.2).
3 Z0 S0 l- l' U4 ySome experimenting finds that the indices (1.38, 1.65, 2.2) appear to work best, giving widest possible bandwidth of about 30 nm: 535 to 565 nm. As the bandwidth is increased, it becomes more difficult to keep both the reflectance and the phase differences within their required ranges.
3 p) \7 [+ U2 ?2 c. k/ S. |/ RIn all of our designs, we start with a single thin layer and use TFCalc's needle/tunneling optimization to design the beamsplitter from "scratch". The plots below show the performance. Note that the phase differences are split across the last two plots. : |  F0 o/ R! `' |  |  I2 _
/ X% C. G+ [( F" p" J
8 K4 P/ r- j1 Y6 X3 j7 [( _& A' e7 D; F  n' ?- t9 f
, i& a5 I& y; o7 {
0 B5 ~+ e  r7 l3 Q4 |( v If you want a copy of the design file, please send e-mail to info@sspectra.com. The contest results will be announced at the OIC meeting in Tucson, June 6, 2007. This design was not entered in the contest.
GMT, 2026-5-2 , Processed in 0.025045 second(s), 23 queries .
