查看: 977|回复: 1
[讨论] ito
QQ
发表于 2010-2-26 23:28:56 | 显示全部楼层 |阅读模式
薄膜产品
" P1 b- A& p6 A/ T" ]/ c) P         SR050CO                                    2 ~- C1 x( `' z  ^2 |
                                            8 O# F0 q; i8 ~& {7 @4 f% \  j8 {
1.OptICAL Properties                                            3 W( k$ F# ~# N! k
/ o# H- [/ ~3 P7 M# KITEM    Reflectance(%)
8 z. r- a# ~  P8 I- PSRF050PW    Wavelength(nm)    400    450    500        550        650            700
5 d) I5 E+ W/ P    SPL1    88.96    93.69    95.73        96.87        98.04            98.41
  z0 }% p' w% Q" q6 K; b    SPL2    88.79    93.65    95.74        96.91        98.11            98.5
9 v% I% t9 F3 H: A# X    SPL3    88.91    93.78    95.84        96.93        98.13            98.49
$ b0 E+ \0 x" S5 Y# U7 t    SPL4    88.67    93.58    95.68        96.83        98.02            98.4) O4 Q# p- G- j; R, k  r& J& x
    SPL5    88.84    93.69    95.8        96.95        98.17            98.53  s0 Z8 X3 M5 ?5 a% }
    SPL6    88.64    93.63    95.79        96.92        98.16            98.5
: E+ y5 _; Y) m# n5 s9 `3 E    SPL7    88.76    93.64    95.69        96.84        97.97            98.34+ d6 `- V1 S! Y
    SPL8    88.77    93.63    95.7        96.85        98.05            98.38" m' c) w; Z- m+ s
    SPL9    88.85    93.81    95.89        97.01        98.23            98.622 |5 o7 ]& j0 N
    SPL10    88.91    93.79    95.85        96.97        98.11            98.45; K# q. J1 S4 Y# D: U0 \! L8 u2 A
    AVE    88.786    93.7    95.784        96.918        98.104            98.4586 N8 ^- J2 D) s+ `# Z% \9 Z% d
/ P- u5 `' o( N: E0 u8 F$ f# H2.TYPICAL Properties of SR050CO                                            2 C) u8 U' b; o; N$ ?6 `
item            Unit    SPEC    Remark                        2 l- H( D: |. l: N2 w2 B
Totai Thickness            um    50±3    ASTM D 1005
$ T/ p/ Z" Y9 ^9 W8 Y" _Optical    Reflectance    450nm    %    93.0以上                            2 o7 d; |+ O, i! U; \: V% q6 @
        550nm    %    96.0以上
' Q% p$ e# r; \/ {; n        650nm    %    97.0以上                            $ _. W: q! p1 S, \' g$ f" w
    Transmittance    550nm    %    0.1以下    ASTM D 1003
6 E, n/ F% |5 |$ r7 I( B" TMechanical    Tensile Strength    MD    Kg/mm2    26.6    ASTM D 882
% l, \/ j* G7 H" ~3 g        TD    Kg/mm2    30.2                            ( y6 F$ ^5 K& j# a0 f
    Elongation    MD    %    155以下                            ' A2 Y- L+ s/ f7 F6 l2 m
        TD    %    125以下                            & m! z5 C; Q% N" u
Thermal    Heat Shrinkage    MD    %    1.1以下    30 min at 150℃                        ' V/ N" M3 k) l, h; G2 T/ `; z9 U
        TD    %    1.0以下
1
发表于 2010-3-16 06:27:08 | 显示全部楼层
谢谢大公无私的分享
GMT, 2025-10-16 , Processed in 0.030344 second(s), 23 queries .
