查看: 676|回复: 0
[分享] 188CC-F91118H303-M011
QQ
发表于 2010-2-26 23:06:26 | 显示全部楼层 |阅读模式
薄膜产品INSPECTION REPORT
1 `4 {% u6 [, l2 z9 j8 Q' d                                    2 h9 C+ I5 R" d" q% M
Provider        PRO-VISION        "Q9 m  B6 D9 O( a  m% h
C"    Prepared    Checked    Approved
: j+ @0 {* x! ^4 i$ V1 D8 qProduct NO.        PVF400-188CCM
7 F1 w) ~! \) V( m* r5 OSize.        500mm*10M                            $ w+ H& t( y7 ]7 c  n) T6 C$ ]
Lot NO.        188CC-F91118H303-M011                            $ Q* v3 Q5 I' y( Z) ^
Inspection Date        2010/1/27        Date
$ I7 [1 j- q9 l5 t
9 \, ~) r& c7 L. a+ z                                    2 |& D) _- ~; |( X) |
        Inspection SECTION            UNIT    SPEC        RESULT    DCSN- L$ w2 j9 _8 y& K: G- i% M
1.Dimension of Roll
8 _' v+ a( p7 C' G        Thickness            um    188±18.8(10%        196    Pass
5 N  ?( M$ }* _$ ]$ Y        Width            mm    —        500    Pass
" d# z2 b8 E0 w: V9 g& X, _* B! ^        ITO coated side            —    inside        inside    Pass
( P$ X# ~2 Z8 V" c& s/ B
+ i$ u6 o( o4 G9 Z' C+ |% P, @2.Optical Properties(After annealing at 150℃,1Hour)                                      U# _! ]3 f7 _
        Total Tansmittance            %    ≧87        89.21    Pass
3 x; ~' l* c8 I5 J2 j1 D6 Z) b# N+ w: m        Haze            %    0.5±0.3        0.44    Pass  W  H5 d+ K  U: @; U
        b*            %    2.5±1.5        1.95    Pass
  F0 B0 i9 m5 \4 g
* u" @$ [3 y$ ?3 @! o% z                                      M0 N3 N" M4 h. e. \; Y$ g
3.Electric Properties
9 ]9 \' ^2 t5 N6 _6 p5 R        Sheet Resistance(RO)            Ω/square    400±80        330    Pass
, v9 C' {; t  A3 s( b+ R  }  F2 E        Sheet Resistance(150℃/1HR)(R1)            Ω/square    350±80        301    Pass
& }; O5 U" E+ a, R/ M/ u        Uniformity            %    ≧10        2.80%    Pass
) C2 {  O) L, u5 h
5 U  ]  u$ M8 j3 V" o# ?
; N* |7 N" C  C5 q4.Mechanical Properties                                    $ G, I$ O5 H3 J9 `
        Non ITO-side Hardness                3H        OK
- Y& H# x; w* [1 J3 z2 F        ITO Adhesion                100/100        OK    3 Z. ]2 g* ?/ a* ?3 v' \
                                    * L1 a; U- O1 D% v
                                    & W- T5 Q. n/ x* M" h
5.Visual Quality                                    ( l, G% T  r- s, F  u3 I% ?4 D, N
        ALL                Spec Sheet        OK    Pass
$ z# l! w  e2 J" `& P8 q4 L
/ J% j/ a0 ], V, i7 ^" p9 \+ n<Remark>                                    5 P% W$ j) i4 h. x  Z6 C3 X
                                    / [3 q5 z! k0 _1 c) f
            CYLUN
GMT, 2025-10-16 , Processed in 0.025157 second(s), 23 queries .
