玻璃基底上双波段增透膜的设计与制备$ C* z1 k) k4 P+ Q
杭凌侠 田刚 潘永强西安工业大学光电工程学院,西安710032摘 要:采用离子束辅助沉积技术,在K9玻璃基底上完成了双波段(0.43~0.9μm及1.54μm)增透膜的设计与制备,单面镀制该增透薄膜的实测光谱曲线表明:在0.43~0.9μm波长范围内,平均透射率大于94.6%,峰值透射率大于95.4%;在1.54μm波长处,透射率不低于93.5%.[著者文摘]
" q6 b+ O3 v) e( ]5 Y, N5 U" g% p1 P* ], N; @( _/ Z, k5 _
关键词:光学薄膜 双波段 增透膜 离子束辅助沉积
/ I6 b. v2 r* Q( C3 ]; P: F$ E分类号: TB43[著者标引]文献标识码:A文章编号:1673-9965(2009)01-001-03栏目信息:光电工程, Y% B o& j6 n
相关文献:主题相关 全文快照 5 {/ @: f3 d6 A }$ D& e# q6 V
% ]" Q( G7 n, c- U0 k
Design and Fabrication of High Performance Antireflection Coatings with Double WavebandHANG Ling-xia, TIAN Gang, PAN Yong-qiang School of Optoelectronic Engineering,Xi'an Technological University,Xi'an 710032,ChinaAbstract esign and deposition of double waveband(0. 43-0. 9 μm and 1. 54 μm)antireflection coatings on K9 Glass substrate by ion beam assisted deposition are reported. Single-surface coated substrate shows an average transmission of greater than 94.6% in the range of 0. 43-0.9 μm and the maximal transmission is greater than 95.4%,transmission is not less 93.5% in the waveband of 1.54 μm[著者文摘]: f N: L0 l0 P* \5 y) P" z
; L% O* r E- m S* V9 Z
Key words ptical film;double waveband ;antireflection coatings ; ion beam assisted deposition (IBAD) |
