查看: 698|回复: 0
[转贴] 以Au和Au-Cu为衬底的Si/DLC薄膜的机械性能
发表于 2010-1-15 03:26:17 | 显示全部楼层 |阅读模式
6 |, w  }& K4 r. X* U  F; t屈少华[1] 贾丽慧[2][1]襄樊学院物理系,湖北襄樊441053 [2]武汉工程大学化工与制药学院,湖北省新型反应器与绿色化学工艺重点实验室,武汉430074摘 要:通过纳米划痕测试技术(nano-scratch)研究了以Au和Au-Cu(xAu=93%,xCu=7%)为衬底,多晶硅Si为基片的类金刚石(DLC)薄膜的机械性能,其中DLC薄膜厚度约为10nm.研究结果表明,Au-Cu衬底对Si/DLC薄膜的结合力比Au衬底对Si/DLC薄膜的结合力要好.紫外(244nm)为激发光源的拉曼光谱测试结果显示在相同薄膜制备条件下Au-Cu衬底比Au衬底含有更多的sp3成分,同时也意味着以Au-Cu为衬底的Si/DLC薄膜具有更高的硬度和密度.通过对研究结果的分析讨论可以得出,由于具有较好的结合力和高硬度,Au-Cu是磁记录磁头保护膜Si/DLC薄膜的更好lead材料.[著者文摘]
: B5 E& c! N- F9 N, Z2 X6 s, h% |7 ?# w, R
关键词:拉曼光谱 类金刚石薄膜 结合力 硬度/ I' c5 X9 [* z, c5 i+ g
分类号: O647[著者标引]文献标识码:文章编号:栏目信息:研究论文
8 U+ M' ?* Y( M0 D* J+ z/ V9 t相关文献:主题相关 全文快照   4 R0 q, S' T! j8 @4 o
+ x; a4 O6 a. Z/ ?1 yMechanical Properties of Si/DLC Films on Au and Au-Cu SubstratesQU Shao-Hua JIA Li-Hui 1Department of Physics, Xiangfan University, Xiangfan 441053, Hubei Province, P. R. China; 2School of Chemical Engineering and Pharmacy, Wuhan Institute of Technology, Hubei Key Laboratory of Novel Reactor & Green Chemical Technology, Wuhan 430074, P. R. ChinaAbstract:The mechanical properties of Si/DLC(diamond-like carbon,around 10 nm) films on Au and Au-Cu(xAu= 93%,xCu=7%) substrates were studied by nanoscratch tests.Results show that Au-Cu exhibits better adhesion to Si/DLC than Au does to Si/DLC.Ultraviolet(244 nm) Raman spectra show that DLC films on Au-Cu contain more sp3 character than those on Au using the same batch coating process.This indicates greater hardness and higher density of the films on Au-Cu.The implications of these results on the mechanisms proposed for film formation are discussed.Au-Cu is thus a better candidate for use as a lead material in Si/DLC coatings because of its better adhesion and greater hardness for magnetic recording sliders.[著者文摘]
0 R# _2 E: R0 n* }4 v4 O6 ^6 k5 E" V1 M
! w4 f$ c  a+ l5 J  JKey words:Raman spectroscopy; Diamond-like carbon film; Adhesion; Hardness;
GMT, 2026-6-11 , Processed in 0.020893 second(s), 25 queries .
