查看: 1771|回复: 0
[转贴] 高重复频率DPL激光辐照光学薄膜元件温升规律实验研究
发表于 2009-10-10 03:45:40 | 显示全部楼层 |阅读模式
% a; W# |8 k% w8 G6 O# g0 p    % ]3 m/ T1 `- Z2 W% @8 p0 E8 z
: l4 \8 b+ P! J4 e: O# L
) k5 p$ G- U1 O6 H+ W / m0 r  }; _5 Y+ `8 j
【英文篇名】 The temperature rise of optical films under DPL-pulsed laser irradiation of high repetition rate & I6 s" w7 |3 _8 D
【作者中文名】 代福; 龚自正; 牛锦超; 曹燕;
! q. n6 {- r# W8 |: i【作者英文名】 Dai Fu; Gong Zizheng; Niu Jinchao; Cao Yan (Beijing Institute of Spacecraft Environment Engineering; Beijing 100094; China);
# w, o( g; [  G0 d/ \7 Y9 }4 |% r【作者单位】 北京卫星环境工程研究所; 2 n( f3 R% V0 O# G! h8 P9 {( h
【文献出处】 航天器环境工程, Spacecraft Environment Engineering, 编辑部邮箱 2009年 03期  4 D, l5 q* O; M* R: ~+ {
期刊荣誉:ASPT来源刊  CJFD收录刊   y" U6 c" S3 \, R; r; o3 F
【关键词】 脉冲激光重复频率; 红外热像仪; 热导率; 吸收峰值功率密度; 光学薄膜; 9 n+ B+ R6 h* }5 L" Z- t- W
【英文关键词】 pulsed laser repetition frequency; DPL; infrared thermography camera; thermal conductivitys; absorbing power density; optical films; 8 c5 u* _+ M% `7 O+ U# z0 s7 l
【摘要】 光学薄膜是激光系统中最易损坏的薄弱环节。在高重复频率脉冲激光辐照下光学薄膜表面温度急剧上升,导致膜层应力、结构发生变化,最后出现宏观的灾难性损伤。文章采用红外热像仪实时测量了重复频率10kHz的DPL脉冲激光辐照下光学薄膜元件表面激光辐照中心点的温度变化,分析了影响薄膜元件温度变化的众多因素。结果表明,采用热导率较大的材料作基板的薄膜样品表面的温升较低;基板厚度越大的薄膜样品表面温升越低;薄膜表面激光辐照中心点的温度与样品的吸收峰值功率密度呈线性关系。 + I9 R$ i+ W; S9 J' s- I
【英文摘要】 Optical coatings are the uttermost weak link in the laser system and may easily be damaged. The temperature of films rises quickly under the irradiation by a pulsed laser of high repetition rate, that leads to a sharp variation of the stresses in the coatings and their configurations, and is followed by macroscopic and catastrophic damages. In this paper, we measured the maximal temperature variation in films irradiated by DPL laser with repetition rate of 10 kHz in real time using infrared thermography cam... 0 q) y2 d- l2 |- M0 S
【基金】 国家高技术激光技术支持项目
GMT, 2026-3-27 , Processed in 0.020877 second(s), 24 queries .
