楼主 |
发表于 2009-8-25 09:17:53
显示全部楼层
引用第3楼121331768于2009-08-24 12:26发表的 :
8 D/ u# D) P$ i$ E! N好像似乎失效了啊,连接不上了。 刚才试过,可以连接6 F8 h+ n/ O" y7 k7 Q) i
FlashFXP v3.7.5 build 1292 [BETA]
% K" N% N5 d& E9 t; p( q. `Support Forums at http://forum.flashfxp.com
9 Y; N- d, ^6 Y9 m1 Q) s, QReport a Bug at http://bugtracker.flashfxp.com6 i. |% V0 P4 O% k: Q
" W; u! q$ t1 h$ b
WinSock 2.0 -- OpenSSL 0.9.8h 28 May 2008
8 G5 c. S. }/ |/ K4 t6 U1 p% Q[R] 正在连接到 218.196.240.23 -> IP=218.196.240.23 PORT=219 C8 C5 c# x* T
[R] 已连接到 218.196.240.23
! D- N- i' Q4 Z3 o+ b/ d[R] 220-Serv-U FTP Server v6.0 for WinSock ready...
: B1 B/ K6 [. s* l0 q. `[R] 220-20:11:15 - displays the current time on your PC
/ m8 q3 p1 N: @8 I( R[R] 220-Sunday 23 August, 2009 - displays the current date on your PC
% J6 A/ Q. P2 L# B+ Y( y4 n% y; s[R] 220-8 A- w& Y5 _$ d2 Z0 h7 d
[R] 220-10 - displays the number of days the server has been running
, B0 _! Z* e: F8 S[R] 220-17 - displays the number of hours the server has been running
, S1 v' O& k; g" p[R] 220-0 - displays the number of minutes the server has been up
6 l) K3 r; ~. X1 L6 P& T[R] 220-40 - displays the number of seconds the server has been up
) x8 c$ N" x6 {6 T# I) E[R] 220-0 - displays the no. Kbytes uploaded to the server since server start
% x: [9 ]. a6 _. }[R] 220-1241339244 - displays the no. Kb downloaded from the server since server start
& E X( Q+ }* i6 ~4 ?' { R[R] 220-0 - displays the no. of files uploaded to the server since server start; z1 U$ p% a7 c8 M6 K/ y
[R] 220-15992 - displays the no. of files downloaded from the server since server start
" b, o. Q7 h& t- q1 Q" G[R] 220-847163 - displays total no. of logged in users since server start
- U: L0 e6 L/ }+ Z[R] 220-1341.640 - displays the average server throughput since server start- ?; f% ^' V1 q8 U/ W' G8 K5 \
[R] 220-2029.998 - displays current server bandwidth use
4 x4 Y7 T7 B7 ~[R] 220-
2 s" n5 H. f1 D, z2 ^* P[R] 220-Unlimited - displays the maximum no. of users, as set in 'Settings - Domain', G! }4 v1 g1 x, \, J
[R] 220-Unlimited - the maximum no. of anonymous users, as set in 'Settings - Domain') N) m; ]4 K6 D' ]' p5 X9 r
[R] 220-
/ \& g# H& V5 S7 |- G0 `[R] 220- - displays the user's login name/ y; k( ?) B6 |6 S
[R] 220-221.237.65.165 - displays the user's IP number or name if available
# W# D& o b/ ^- F# n[R] 220-/C: - displays the user's current directory$ V' l% B0 H; B6 p/ \1 h. ?
[R] 220-C - displays the user's current disk drive
: M# |, e' L6 }0 b; a; I[R] 220-7935.69 - displays the amount of free space on the user's current disk in Mb
5 f2 T" @2 R$ G0 V" _* E$ K[R] 220-0 - displays the number of files uploaded by the current user
0 R7 u% I `/ T6 q& J; E[R] 220-0 - displays the number of files downloaded
/ l" B) s6 @4 N[R] 220-0 - displays the total number of files transferred
( x3 J% X+ K0 N8 X T& r' h; N[R] 220-0 - displays the number of Kbytes uploaded by the user4 y9 w# H7 e$ S$ r! x
[R] 220-0 - displays the number of Kbytes downloaded by the user) M* y9 A9 y8 p2 h% c( K: s1 m
[R] 220-0 - displays the total number of Kbytes transferred3 U* i! u3 E: g: L& I' _
[R] 220-0 - displays the total connect time in minutes
' a: s1 [: k" `' g9 |$ B/ b[R] 220-0 - displays the connect time in seconds - to be used with '0'/ |# G: G% A6 A i( ]4 r
[R] 220-1 - displays the 'upload' ratio part for UL/DL ratios0 U' [* b2 e2 s% V2 `9 l
[R] 220-1 - displays the 'download' ratio part for UL/DL ratios- G+ |/ b$ S! w/ k" w5 e
[R] 220-0 - displays the current download credit for UL/DL ratios (Kb or 'files')( k( U+ x) k4 ` o* @
[R] 220-0 - displays how much disk quota is used in Kb
9 H$ p! H4 t7 f* g$ n* z[R] 220-Unlimited - displays how much disk quota is left in Kb
. u9 A8 v- s1 k" {8 v[R] 220-Unlimited - displays the maximum amount of disk space that can be used in Kb
3 j' e' {/ r# ^9 A[R] 220-, H; h+ @7 T# l
[R] 220-119 - displays the current number of Serv-U users connected
9 |9 ^4 f% P3 M9 [) c[R] 220-2784274 - displays the number of users since the server was started
3 z* g" G. N3 n5 Z6 {, b4 ~[R] 220-241185 - displays the number of users in the last 24 hours( n# x' P7 t7 m2 o# w/ T( t
[R] 220-104 - all currently logged in anonymous users
1 P+ T3 z, ^6 \1 c3 v7 `[R] 220-95 - all anonymous users logged into this IP home
4 ^( I! |* ~$ E0 x[R] 220-15 - all non-anonymous users currently logged in
9 X$ N4 r) a8 G3 O5 `. M[R] 220-24 - all non-anonymous users logged into this IP home2 p# @4 l0 b% T, ]0 ~7 ]" q
[R] 220 119 - all current users with the current user name logged into this IP home
. L; s9 R8 J2 L, B( |, X: W[R] USER anonymous C: a+ H( M& ?
[R] 331 User name okay, please send complete E-mail address as password.
7 h0 j6 B: O+ Y- D[R] PASS (hidden)
/ D2 b2 L: k+ R[R] 230 User logged in, proceed.
; D; c: @6 p: D0 g# K7 l6 o' w[R] SYST: a3 Q# T( H7 \9 G
[R] 215 UNIX Type: L8: I0 X% h# R9 l( a" ^* S
[R] FEAT
( C M9 p+ M4 B. t$ L! y' f3 l[R] 211-Extension supported5 E$ p1 B9 R) b( x+ t
[R] CLNT
0 `# g1 ~7 x7 b[R] MDTM+ H: | G: p5 ^& [, ^8 ~0 y" z& O6 _
[R] MDTM YYYYMMDDHHMMSS[+-TZ];filename, t$ c: ?' O- H% s: ^* a- u
[R] SIZE
7 d/ i# f9 a h4 l& j# ^[R] SITE PSWD;EXEC;SET;INDEX;ZONE;CHMOD;MSG0 A. Z3 i) K4 N! W; O5 Y3 D
[R] REST STREAM
4 m4 K# ]; v2 j[R] XCRC filename;start;end- ]5 z5 V e2 |: P, }2 i
[R] MODE Z
. ?' [ }0 k& Y' J: X0 L7 r[R] 211 End
0 M' c9 G, p1 C$ j! n[R] CLNT FlashFXP 3.7.5.1292
) G" E1 h$ Y- H; h- ^# l- @9 s[R] 200 Noted.
( V" a3 r5 [# |[R] PWD3 \- X2 k+ C1 g; p0 f
[R] 257 "/" is current directory.+ u; @# c5 n8 [+ R: A
[R] TYPE A) }/ f1 K( e1 x2 i9 q
[R] 200 Type set to A.
" y% i" s6 ]6 n9 l1 O[R] MODE Z- ]" u1 N5 [7 e+ F- _7 J
[R] 200 MODE Z ok.
% G, _: I) |# ]% F# h6 C[R] PASV. L" X3 d8 w9 x3 p0 U
[R] 227 Entering Passive Mode (218,196,240,23,4,115)' T1 H( Z6 e( T. y) Q( {
[R] 正在打开数据连接 IP: 218.196.240.23 端口: 1139$ Y; |1 k. L+ C& f: G4 P m! h
[R] LIST -al {$ `( \4 N8 a
[R] 150 Opening ASCII mode data connection for /bin/ls.
+ h2 E* c* W( g. T[R] 226 Transfer complete.
1 c3 E, Z3 |/ Y! Q. }; R) I[R] 列表完成: 1,011 字节 用时 0.70 秒 (1.4 KB/s)
+ m3 O5 [% b7 J4 l2 t7 |& M. V: H[R] CWD 教育教学& D) \( D. Y& U" y F
[R] 250 Directory changed to /教育教学
+ z5 j' f8 V% z6 ?1 `+ Q6 \[R] PWD* Z3 y9 Y. m0 w: A
[R] 257 "/教育教学" is current directory.
+ N- n' S5 o2 g[R] PASV) G8 ]. u, w* ~
[R] 227 Entering Passive Mode (218,196,240,23,4,122)
9 w2 u: a3 o( Z5 Y9 s' I[R] 正在打开数据连接 IP: 218.196.240.23 端口: 1146' Q7 T4 u& V) u$ U/ d3 r$ x% \
[R] LIST -al
! ^1 a$ o. y+ L! ^! _[R] 150 Opening ASCII mode data connection for /bin/ls.
1 z& O' J; J2 L r) ]) N( ?! S[R] 226 Transfer complete.* f- d- X) @) ^& ], [# C7 x
[R] 列表完成: 2 KB 用时 2.99 秒 (0.9 KB/s)5 ]& f% o) q5 h" g1 Z0 W
[R] CWD 书籍9 P' b% N7 s% a" N6 {3 u; K
[R] 250 Directory changed to /教育教学/书籍
, J/ ~7 j7 b+ d. l& K[R] PWD7 E# K& z m* l$ f8 H/ j
[R] 257 "/教育教学/书籍" is current directory.1 V& f" L7 p5 R# j& i% }- n
[R] PASV
4 W$ H1 l) u1 l* Q/ _# H[R] 227 Entering Passive Mode (218,196,240,23,4,131)
) m7 P w7 Y# a[R] 正在打开数据连接 IP: 218.196.240.23 端口: 1155
, z( w7 `; p; Z5 M/ B[R] LIST -al
/ {6 @* T! c2 f! n* b \; V[R] 150 Opening ASCII mode data connection for /bin/ls.: O# Z. Y$ b t% G, S4 x
" L# e# C7 s- r[R] 列表完成: 931 字节 用时 0.46 秒 (2.0 KB/s)
/ M [! W# G* J7 N" y$ d[R] CWD /其它软件4 d' D$ n- W- s' g
[R] 250 Directory changed to /其它软件8 `1 ^8 F' s6 ^! x
[R] PWD9 e3 K; ]/ D1 G8 w" \
[R] 257 "/其它软件" is current directory.4 l, M2 g$ \! i; a! v
[R] PASV
$ D+ j8 M( q0 P& `[R] 227 Entering Passive Mode (218,196,240,23,4,186)) s9 w; h. a% v9 V
[R] 正在打开数据连接 IP: 218.196.240.23 端口: 1210
* p* y8 }" w# ]8 [[R] LIST -al! g" K' a# Y7 N. g; H- m1 j
[R] 150 Opening ASCII mode data connection for /bin/ls.3 z) ]% p' e7 e4 K; ^( M0 z
, H Q0 y7 o* U5 Q3 g6 b- L6 B[R] 列表完成: 3 KB 用时 0.43 秒 (8.0 KB/s)
T0 y7 v" m P: I$ O[R] CWD /游戏娱乐
8 M# x- p: b; p3 f7 \[R] 250 Directory changed to /游戏娱乐
: M$ t' w) f% ?! ~[R] PWD
0 m7 E- |7 T! F6 D4 X k[R] 257 "/游戏娱乐" is current directory.+ b$ ]- j( D. j9 n/ H7 ~
[R] PASV
% ~1 q( ~/ }% n) }8 d# _$ P[R] 227 Entering Passive Mode (218,196,240,23,4,205), `: Y9 a4 Y3 x% `
[R] 正在打开数据连接 IP: 218.196.240.23 端口: 12297 F; M* `) F9 g% D
[R] LIST -al9 D7 Z/ x8 V9 Q3 @
[R] 150 Opening ASCII mode data connection for /bin/ls.# H2 h: G" B# c7 y
[R] 226 Transfer complete.7 Q3 O. U1 U1 A% A, R
[R] 列表完成: 2 KB 用时 0.52 秒 (4.5 KB/s)9 [" F9 _. x; E8 z( s- r8 J6 l
[R] CWD /共享文件夹
- g& ^# o; F( r3 {* v[R] 250 Directory changed to /共享文件夹* {1 N; I; E0 g% e/ F
[R] PWD
2 l5 B5 t4 j) C# ~1 T: Y[R] 257 "/共享文件夹" is current directory.. Y3 _7 E" E2 e, P3 A% _
[R] PASV/ o5 m5 S, V8 [2 I1 a
[R] 227 Entering Passive Mode (218,196,240,23,6,58)
) Y2 V' q" z" G8 p* T4 H[R] 正在打开数据连接 IP: 218.196.240.23 端口: 1594, f. g2 ^& {! f
[R] LIST -al
& `) n5 X9 `: Q3 s: a5 v[R] 150 Opening ASCII mode data connection for /bin/ls.
- t+ E M* I" y0 L/ v[R] 226 Transfer complete.
/ P5 ]% m; f7 N L$ B" w V0 A8 u; O[R] 列表完成: 5 KB 用时 0.89 秒 (6.5 KB/s) |
