宽幅薄膜高真空卷绕蒸发式镀膜机的研究与设计' D5 P) E9 o3 l3 I" v, Q
丁学恭[1] 蔡海涛[1] 何勇[2][1]杭州技术学院机电工程系,杭州310018 [2]浙江大学生物系统工程与食品科学学院,杭州310029摘 要:为满足农产品及食品深加工中1500mm幅宽以上的聚脂薄膜(PET)、定向聚丙烯薄膜(OPP)、聚丙烯流涎薄膜(CPP)、聚乙烯薄膜(PVC)的真空镀铝,针对国内卷绕蒸发式真空镀膜机设备存在的工艺参数多、工艺重复性差、操作复杂、产品质量不稳定、设备故障率高等问题,采用高真空技术研制了宽幅卷绕蒸发式高真空镀膜机.测试分析表明,该机上室和下室的极限真空度分别达到了9.0×10^-2 Pa和6.7×10^-2 Pa,恢复真空时间小于8 min,镀膜厚度600~700А,并具有卷取性能好、镀膜幅度宽、镀膜速度快、跑偏量小、镀膜层牢固、均匀等特点,为食品和农产品深加工提供了一种新型的卷绕蒸发式高真空镀膜机.[著者文摘]
y% h0 D- \- z# S/ e# ^2 o$ }( K3 Z! J- n* L6 H; x
关键词:镀膜机 宽幅镀膜 高真空 真空镀铝# H; ?* Q& ]8 R& A' ?7 m
分类号: TG386.32 TH6[著者标引]文献标识码:A文章编号:1002-6819(2007)8-0145-05栏目信息:农业装备工程与机械化+ T8 p3 M1 e2 e' p) \; B$ |5 h1 O
相关文献:主题相关 全文快照 5 k6 C3 Y$ j5 ]2 J# |0 M
, Q7 A7 r `9 T( R( t
Research and design of higher vacuum evaporation coating equipment for big width film platingDing Xuegong, Cai Haitao, He Yong 1. Department of Mechanical and Electrical Engineering, Hangzhou Technical College, Hangzhou 310018, China; 2. College of of Biosystems Engineering and Food Science, Zhejiang University, Hangzhou 310029, ChinaAbstract:In the deep processing of agricultural and food products, there are some key technological problems of system design on the domestic traditional reelable vacuum aluminium coating system, including mass process parameters, bad process duplication, unstable production quality caused by complex operation, and high equip- ment failure rate. A newly developed reelable vacuum aluminium coating system with 1500 mm-wide thin plastic films was designed with high vacuum technology in order to satisfy the vacuum aluminum coating of more than 1500 mm-wide, such as polyethylene terephthalate (PET), oriented polypropylene (OPP), polypropylene cast film (CPP), polyvinyl chloride(PVC). The test analysis indicated that the ultimate vacuums of upper and lower chambers achieved 9.0 × 10^-1 2 Pa and 6.7× 10^- 2 Pa, respectively. The vacuum recovering time was shorter than eight minutes and the coating thickness was from 600А to 700А. There are several advantages of this new system, including good crimp property, wide coating amplitude, fast coating speed, small straight deviation, firm and even coating. Thus, a newly reelable vacuum aluminium coating system was developed for the deep processing of agricultural and food products.[著者文摘]- s' ], o' Y. i' g" N* n8 ^) }
, |* N+ z0 p1 x' ^
Key words:coating equipment; big width of coating; higher vacuum;vacuum aluminum coating |
