基于PLC的真空溅射镀膜机控制系统设计
& R* i1 L# t6 n1 M6 x刘进志 郝长生 刘希太石家庄铁道学院机械工程分院,石家庄050043摘 要:真空溅射镀膜技术及设备在当今和未来都拥有十分广阔的应用领域和发展前景。由于采用继电器-接触器的镀膜机存在一些缺陷和不足,设计了基于PLC的真空溅射镀膜机。几年的实践证明:改进后的镀膜机工作效率有很大提高,设备维修率也大大降低,它为同类系统的设计提供了参考。[著者文摘]
: a: {! `3 f! o ^7 `! D' v7 c7 ]7 j
关键词:继电器-接触器控制 PLC控制 真空溅射镀膜机
d1 Q* Y3 }+ R. W分类号: TP39[著者标引]文献标识码:A文章编号:1003-0794(2008)01-0179-03栏目信息:计算机应用
+ N8 Q4 e6 M) N) }相关文献:主题相关 全文快照 ! h- P5 q- X9 }* M% ?+ F
0 E/ G- _7 k* A$ h# Z5 o- T! e
Design of Control System on Vacuum Sputtering Plating Machine with Programmable Logic ControllerLIU Jin- zhi, HAO Chang- sheng, LIU Xi- taiMechanical Engineering College, Shijiazhuang Railway Institute, Shijiazhuang 050043, ChinaAbstract:The technology and equipment of the vacuum sputtering coating have the extremely broad application and the development in the future. Because the plating machine with the relay - contact control system has some defects, the plating machine with programmable logic controller is designed, several years practice proves. The efficiency of the plating machine that is innovated improves greatly, and its maintenance probability decreases greatly. It also provides reference for similar system.[著者文摘]
% L" S7 U& A9 Q; S" H
$ c( W1 I" }+ D* YKey words:relay- contact control; PLC control; vacuum sputtering plating machine |
