热循环、真空紫外辐照对Al/Kapton薄膜的损伤效应7 n: ~! U# P( Z% P! Q, o/ i, N( X
万志敏[1] 房光强[2] 刘宇艳[3] 杜星文[4][1]哈尔滨工业大学分析测试中心,哈尔滨150001 [2]上海宇航系统工程研究所,上海201108 [3]哈尔滨工业大学高分子材料系,哈尔滨150001 [4]哈尔滨工业大学复合材料与结构研究所,哈尔滨150001摘 要:在空间环境地面模拟设备中模拟热循环、真空紫外辐照等低地球轨道空间环境对Al/Kapton薄膜的损伤效应.利用原子力显微镜、紫外可见分光光度计对试验前后试样的表面形貌、光学参数等性能进行了分析.结果表明,热循环、真空紫外辐照使Al/Kapton薄膜试样产生质量损失,表面形貌发生不同程度的改变,在紫外可见波段的反射率下降明显.[著者文摘]
7 Y4 X. w2 @ l3 O2 k% l) [6 v* u' W/ \8 w+ C8 _
关键词:热循环 真空紫外辐照 空间充气结构 光学性能
4 b* w) {$ `3 n9 i8 ]分类号: V524.3[著者标引]文献标识码:A文章编号:1005-0299(2009)01-0062-04栏目信息:
$ B, O, l3 @ d$ C- Q相关文献:主题相关
8 h5 P* y- v5 l* D. N" V5 U% Q; S3 J% @3 P
Damage effects of thermo-cycling and VUV radiation on Al/Kapton filmsWAN Zhi-min, FANG Guang-qiang , LIU Yu-yan, DU Xing-wen 1. Analysis and Measurement Center, Harbin Institute of Technology, Harbin 150001, China; 2. Shanghai Institute of Aerospace System Engineering, Shanghai 201108, China ;3. Dept. of Polymer Materials, Harbin Institute of Technology, Harbin 150001, China;4. Center for Composite Materials, Harbin Institute of Technology, Harbin 150001, ChinaAbstract:The effects of thermo-cycling and vacuum ultraviolet radiation in low earth orbit on performance damage of Al/Kapton films were investigated using space environment ground-based simulation facility. An atomic force microscope (AFM) and a spectrophotometer were used to characterize the morphology of the surface layer of A1/Kapton films and their reflectivity. The results suggest that thermo-cycling and VUV radiation make the mass loss of Al/Kapton film samples, with the changes of surface morphology to some extent and significant decrease of reflectivity in the ultraviolet visible wave band.[著者文摘]$ W" K$ }2 C- g# g
3 U3 x( m, ^0 \( J4 v* P/ `& Q
Key words:thermo-cycling; vacuum ultraviolet radiation; space inflatable structure; optical properties |
