多层结构钛酸锶铅薄膜及介电调谐与温度稳定性+ v* V" X( C1 w) h
吴文彪 周栋义 金灯仁 孟中岩上海大学材料科学与工程学院,上海200072摘要:在研究组分、溶胶浓度对钛酸锶铅(10ST)薄膜结构、介电、调谐性能等影响的基础上,设计一种以低损耗-高调谐-低损耗组分交替沉积的方法,研制了三明治多层结构的PST薄膜(PST20-40-20).研究结果表明,这种三明治多层结构的薄膜表面致密,晶粒均匀,同时具有调谐率高、损耗低等特点,综合性能比单组分要好,其调谐率、优值分别为52和45.在20~100℃范围内调谐率变化幅度小于8%,提高了温度稳定性. y1 ?- z9 J5 g6 t9 i, o/ V" j
# c& p0 C7 ?3 A* o8 f v
KeyWord:sol-gel technique ; PST thin films ; muhilayer; dielectric tunability properties ; temperature stability
, `# @( T9 D7 \& m" A9 F) i9 z$ X
+ m* O8 Q& b) ^( q0 ^% J% D7 X( o关键词:溶胶凝胶法 钛酸锶铅薄膜 多层结构 介电调谐性能 温度稳定性
9 P- p% P! [& d1 s/ x. Q3 G
/ f6 I% L+ u6 b分类号:TQ17[著者标引]文献标识码:A文章编号:1007-2861(2008)05-0498-05
) J; X6 @5 Y' N7 a. G! I' sPreparation of Sandwich-Like Multilayered PbxSr1-xTiO3 Thin Film with Study of Dielectric Tunability and Temperature Stability WU Wen-biao, ZHOU Dong-yi, JIN Deng-ren, MENG Zhong-yan School of Materials Science and Engineering, Shanghai University, Shanghai 200072, China
( h- i# L0 z' A! ~6 |- sAbstract:A sandwich-like muhilayered lead strontium titanate PbxSr1-xTiO3 (PST20-40) thin film was fabricated on Pt/Ti/SiO2/Si substrates using the sol-gel technique. PST20-40-20 thin films have high tunability and low loss tangent. Tunability and FOM of PST20-40-20 thin films are 52 and 45, respectively. PST20-40-20 thin films have weaker temperature dependence, and the decreasing rate of tunability for PST20-40-20 thin films is about 8% at 20 ℃ to 100 ℃.9 ^8 Y0 q% j+ t0 A( b5 X
6 _% r+ y& e L& Q! f& t
KeyWord:sol-gel technique ; PST thin films ; muhilayer; dielectric tunability properties ; temperature stability |
