角度调谐滤光片特性分析及膜系设计/ G. b2 ~- X9 m
俞侃[1,2] 刘文[1,3] 黄德修[1,2][1]武汉光电国家实验室,武汉430074 [2]华中科技大学光电子科学与工程学院,武汉430074 [3]武汉光讯有限责任公司,武汉430074摘 要:对窄带滤光片的倾斜入射特性作了分析.斜入射时其透射通带和峰值会向短波方向移动,透射曲线的稳定性跟滤光片的间隔层结构相关,多腔间使用相同的间隔层可以保证斜入射时有稳定的峰值透射率和带宽,利用该特点可以制备角度调谐窄带滤光片.透射光S和P偏振分量的中心波长随入射角度的增大出现分离现象,产生较大的偏振相关损耗.通过搭配不同厚度的高低折射率材料作为间隔层,改变其有效折射率,使其两个偏振分量的中心波长实现重合.设计了符合密集波分复用(Dense Wavelength Division Multiplexing,DWDM)系统要求的低偏振相关损耗四腔窄带角度调谐滤光片膜系,其可调谐范围达20nm以上,并评估了所设计角度调谐滤光片的调谐性能.[著者文摘]
' }+ G" b0 p; I ~: C/ }5 E
0 u0 j8 }: [1 B0 i关键词:窄带滤光片 倾斜入射 中心波长 等效折射率 偏振相关损耗1 M* e; v0 x4 L
分类号: O484[著者标引]文献标识码:A文章编号:1004-4213(2008)06-1175-5栏目信息:薄膜光学# L/ b3 {7 W2 c
相关文献:主题相关 全文快照
& [( B$ M$ V# C" g9 O2 H. U
! X# r- k( k( _. s0 |Characteristics Analysis and Stack Design of Angle-tuned FilterYU Kan , LIU Wen , HUANG De-xiu1 Wuhan National Laboratory for Optoelectronics,Wuhan 430074, China;2 School of Optoelectronic Science and Engineering, Huazhong University of Science and Technology, Wuhan 430074, China;3 Wuhan Accelink Technologies Co. ,Ltd. ,Wuhan 430074,ChinaAbstract:The characteristics of the thin film narrowband filters used in tilted incidence are analyzed. Its transmission peak and bandwidth will shift to shorter wavelength and its transmission stability relies on the structure of the spacer. Using the spacers of the same structure between the cavities, the filter have a stable transmission peak and bandwidth when it is used in tilted incidence. It can design angle-tuned narrowband filters through the characteristic. The central wavelength of S-polarization and P-polarization will separate when the filter is tilted. It causes the Polarization Dependent Loss. Using different thickness of the high and low index materials for spacer ,the central wavelength of the two polarization can be coincided because the effective refractive index is changed. The stack of four-cavities angle-tuned narrowband filters with low Polarization Dependent Loss is designed and its tunable range is over 20 nm. The tunable performance of the different stacks is evaluated.[著者文摘]
: s! \4 q2 \* @2 v, y6 S, w3 @" \0 d9 t- O+ s* F; i
Key words:Narrowband filter; Tilted incidence; Central wavelength ; Effective refractive index ; Polarization dependent loss |
您需要 登录 才可以下载或查看,没有帐号?注册
x
