红光Nd:YAG激光器用光学薄膜的研制
& y& E( g3 y8 m2 a下载全文% T8 ^6 b$ j. r. O( B3 B
黄庆新 付秀华
; N2 R& V: f% g% [0 T! `长春理工大学光电工程学院,长春130022 摘 要:从产生660nm红光Nd:YAG激光器制作机理出发,分析了其使用的几种光学薄膜,采用光学薄膜理论的矢量合成方法,利用计算机膜系设计软件优化,并经过适当修正后得到便于控制的短波通膜系、二倍频高反射膜系,选择适当的薄膜材料和工艺参数,制备出与理论计算结果相吻合的几种光学薄膜,满足技术指标要求。[著者文摘]6 j, b/ e+ ]- |' L
- L' r; X. y& Z+ f
关键词:Nd:YAG激光器 光学薄膜 膜系设计 二倍频
* G7 {1 \ L* g/ k, q& w- q7 C2 J T1 F, A& F, v
分类号:TN304.055[工业技术 > 无线电电子学、电信技术 > 半导体技术 > 一般性问题 > 材料 > 一般性问题 > 制取方法与设备 > 半导体薄膜技术]文献标识码:文章编号:相关文献:主题相关 参考文献 引用本文
! z( A: a& c5 l. U4 N( sDevelopment of Optical Thin Films for Red Nd'YAG LaserHUANG Qingxin, FU Xiuhua ( Changchun University of Science and Technology, Changchun 130022)Abstract:Based on the manufacturing theory of 660nm red Nd:YAG laser, A series of optical thin film for the laser system were analyzed, using vetorial resultant method ofoptical thin-film theoretical design, utilizing computer coating optimization methods based on the starting design, after appropriate amendment, we have obtained the controllable film system of short-wavelength pass and doubling frequency high reflectance, selected appropriate thin-film material and technological parameter, the results show that there is good compatibility, deposited films can meet the practical requirement..[著者文摘]
: ^- s' D8 P) [- Q; c# NKey words:Nd:YAG laser; optical thin films; design of film system; frequency doubled |
