查看: 4067|回复: 10
[转贴] 硕士论文下载:漸變折射率光學薄膜之設計與製鍍  (指導教授 李正中 )
发表于 2008-12-17 01:21:45 | 显示全部楼层 |阅读模式
[/free]漸變折射率光學薄膜之設計與製鍍
論文名稱(英) The Design and Fabrication of Gradient-index Optical Thin Film
檔案 89226001.pdf
本電子全文僅授權使用者為學術研究之目的,進行個人非營利性質之檢索、閱讀、列印。
請遵守中華民國著作權法之相關規定,切勿任意重製、散佈、改作、轉貼、播送,以免觸法。  論文使用權限 一年後開放
論文語文/頁數 中文/56
統計 本論文已被瀏覽 1289 次,被下載 945 次
摘要(中) 摘 要
由於鍍膜設備的進步使漸變折射率薄膜的製程變得容易,使漸變折射率光學薄膜的設計將會成為重要的課題,而多種設計方法中以傅立葉轉換法最能夠以物理方式推導與理解,不需使用嘗試錯誤或迭代的方式得到結果,所以可快速正確的得到初階折射率分佈與較正確的光譜圖,再由傅立葉轉換法所得的結果作耦合層設計或經由修正輸入之穿透率值得到最佳的結果,而本論文之工作主要分為兩項,一是使用射頻離子束濺鍍方法並利用靶材Ta靶與SiO2靶混合出折射率由2.2變化至1.48且低吸收之光學混合膜,且可有效控制折射率之間隔至0.03以下;二是利用傅立葉轉換之數學式撰寫成電腦程式作漸變折射率光學薄膜之光學成效設計,既是將欲達成之穿透率光譜用傅立葉轉換,轉換成折射率對光學厚度之變化圖,並且能完成初步之自動化鍍膜控制程式,得到預期之光學成效,證明漸變折射率光學鍍膜之可行性。
摘要(英) Abstract
The gradient-index optical thin film design will become an important topic, since the fabrication of gradient-index optical thin film is easier. Furthermore, among the several methods, only the Fourier transform methods can used as a physical means to explain and understand. Thus it is unnecessary to used try and error or substitution method to derive results, so it is fast and accurate to derive a first step refractive index distribution and correct transmittance spectrum. Then Fourier transforms is used to obtain a result for coupled layer design or modify input transmittance spectrum to get the best design. This thesis has two parts, part one is the use of radio frequency ion beam sputtering and moving target coat composite thin film of refractive index continuously varied from 2.2 to 1.48 and low absorption by Ta and SiO2 targets, to effect the control refractive index to a lower interval of 0.03; Part two is to design optical performance of gradient-index optical thin film by using mathematics formula of Fourier transform to write a computer program. That is transform the transmittance spectrum to a refractive index vs. optical thickness curve by Fourier transform, and finish the first step of an automatic coating control program. To obtain the expected optical performance, the proven moving target method for coating gradient-index optical thin film is practical.
關鍵字(中) 漸變折射率光學薄膜
傅立葉合成法
關鍵字(英) Gradient-index Optical Thin Film
Fourier Synthesis
論文目次 目 錄
英文摘要……………………………….……………………………….Ⅰ中文摘要………………………………………………………………..Ⅱ目錄……………………………………………………………………..Ⅲ圖目錄…………………………………………………………………..Ⅴ表目錄…………………………………………………………………..Ⅷ
第一章 緒論………….………………………………………………….1
第二章 漸變折射率光學薄膜之理論與設計方法…..………………....6
2.1 基本理論..……………………………………..………………...6
    2.1.1 在非均勻膜中之波動方程式…..………………………..6
    2.1.2 薄膜特徵矩陣法………………..………………………..9
    2.1.3 傅立葉合成法………..………………………………....12
  2.2 程式模擬與分析……………………………………………….16
    2.2.1 程式模擬……………..…………………………………17
2.2.2 Coupled wave理論……..…………………………….…26
第三章 實驗設備及量測工具……………………….…………...……30
  3.1 實驗設備…………………………………………………….....30
    3.1.1 濺鍍系統……..…………..……………………………..30
    3.1.2 離子源……..……..……………………………………..30
  3.2 量測儀器……………………………………………………….33
    3.2.1 可見光及近紅外光光譜儀……..………………………33
3.2.2 原子力顯微鏡…………………………………………..35
    3.2.3 X-ray繞射儀…………………………………………...37
第四章 實驗結果與分析討論……..…………………………………..38
  4.1 實驗參數……………………………………………………….38
  4.2 光學特性……………………………………………………….39
  4.3 表面粗糙度量測……………………………………………….45
  4.4 結晶性量測…………………………………………………….49
第五章 應 用……..…………………………………………………..50
第六章 結 論……..…………………………………………………..52
參考文獻………………………………………………………………..54
參考文獻 參考文獻
1.M. Zukic and K. H. Guenther, “Optical Coatings with Graded Index Layers for High Power Laser Applications,” Proc. Soc. Photo-Opt. Instrum. Eng. 895, pp. 271-277(1988).
2.W. H. Southwell, “Gradient-Index Antireflection Coatings,” Opt. Lett. 8, pp. 584-586(1983).
3.W. H. Southwell, “Spectral response calculations if rugate filters using coupled-wave theory,” J Opt. Soc. Am. A5, 1558-1564(1988).
4.B. G. Bovard, “Rugate filter theory: an overview,” Appl. Opt. 32, 28, pp. 5427-5442(1993).
5.R. Jacobsson, “Inhomogeneous and Co-evaporated Homogeneous Film for Optical Applications,” Physics of Thin Film, 8, pp.51-98(1975).
6.Tae Uk Ryu, Sung Hong Hahn, Sok Won Kim, Eui Jung Kim, “Optical, mechanical and thermal properties of MgF2-ZnS and MgF2-Ta2O5 composite thin films deposited by co-evaporation,” Opt. Eng. 39 (12), pp. 3207-3213 (2000).
7.Feldman, E. N. Farabaugh, “W. K. Haller, D. M. Sanders and R. A. Stempniak, Modifying structure and properties of optical thin film by co-evaporation,” J. Vac. Sci. Technol. A, 4 (6), pp.2969 (1986).
8.陳至信, “二氧化鈦薄膜性質調變與製程控制,” 國立清華大學電機工程研究所博士論文(1996).
9.M. Cevro, “Ion-beam sputtering of (Ta2O5)1-X(SiO2)X composite thin film,” Thin Solid Film 258, pp. 91-103 (1995).
10.李正中, “薄膜光學鍍膜技術,” 藝軒圖書出版社, 1999年.
11.E. Delano, “Fourier Synthesis of Multilayer,” J. Opt. Soc. Am. 57, pp. 1529 (1967).
12.L. Sossi, Eesti NSV Tead. Akad. Toim. Fuus. Mat. 23, pp. 229(1974)
13.J. A. Doborwolski and D. Lowe, “Optical thin film synthesis program based on the use of Fourier transforms,” Appl. Opt. 17 (19), pp. 3039 (1978).
14.B. G. Bovard, “Derivation of a matrix describing a rugate dielectric thin film,” Appl. Opt. 27, 10, pp.1998-2005(1988).
15.何坤榮, “以傅立葉轉換作為光學薄膜設計,” 國立中央大學光電科學研究所碩士論文(1994).
16.J. A. Dobrowolski and R. A. Kemp,”Refinement of optical multiplayer systems with different optimization procedures,” Appl. Opt. 29, 19, pp.2876-2893(1990).
17.J. A. Dobrowolski, “Completely Automatic Synthesis of Optical Thin Film Systems,” Appl. Opt. 4, pp.937-946(1965).
18.J. A. Dobrowolski, “Versatile computer program for absorbing optical thin film systems,” Appl. Opt. 20, pp.74-81(1981).
19.W. H. Southwell, “Coating design using very thin high- and low-index layers,” Appl. Opt. 24, pp.457-460(1985).
20.J. A. Dobrowolski, “Comparsion of the Fourier transform and flip-flop thin film synthesis methods,” Appl. Opt. 20, pp.74-81(1986).
21.Zdeněk Knittl, “Optics of Thin Films,” John Wiley & Sons. Ltd, 1976.
22.W. H. Southwell and Randolph L. Hall, “Rugate filter sidelobe suppression using quintic and rugated quintic matching layers,” Appl. Opt. 28, pp. 2949-2951(1989).
23.W. H. Southwell, “Using apodization functions to reduce sidelobes in rugate filters,” Appl. Opt. 28, pp.5091-5094(1989).
24.Henrik Fabricius, “Gradient-index filters: designing filters with steep skirts, high reflection and quintic matching layers,” Appl. Opt. 31, pp. 5191-5196(1992).
25.P. G. Verly and J. A. Dobrowolski, “Iterative correction process for optical thin film synthesis with the Fourier transform method,” Appl. Opt. 29, pp. 3672-3684(1990).
26.J. C. Manifacier, J. Gasiot and J. P. Fillard, “A simple method for the determination of the optical constant n, k and the thickness of the weakly absorbing thin film,” J. Phy. E:Sci. Inst., 9 pp. 1002(1976).
27.Tang Q., 1997, “Study on the optical properties originator by the Microstructure of thin oxide film,” Ph. D. dissertation, Kobe Design University, Japan.
28.Alexander V. Tikonravov, “Some theoretical aspects of thin film optics and their applications,” Appl. Opt. 32 , pp. 5417–5426 (1993).
[free]
购买主题 本主题需向作者支付 200 RMB金钱 才能浏览
发表于 2009-1-15 14:34:15 | 显示全部楼层
论文来看看。。。。
1
发表于 2009-2-13 17:12:10 | 显示全部楼层
俺穷人,冇钱买了,可怜啊
发表于 2009-2-20 15:13:18 | 显示全部楼层
俺穷人,冇钱买了,可怜啊
发表于 2009-2-23 18:31:01 | 显示全部楼层
俺穷人,没钱买了,可怜啊
发表于 2009-2-24 21:34:30 | 显示全部楼层
俺穷人,没钱买了,可怜啊
发表于 2009-5-31 03:52:11 | 显示全部楼层
李正中指导的论文应该很不错吧~可惜没有那么多金钱啊~
1
发表于 2009-6-2 17:37:07 | 显示全部楼层
论文来看看。。。。
发表于 2009-6-18 04:08:11 | 显示全部楼层
光学薄膜论坛
发表于 2009-9-14 20:40:44 | 显示全部楼层
买,多少钱啊
GMT, 2026-6-11 , Processed in 0.028947 second(s), 29 queries .
