查看: 1074|回复: 0
[转贴] 光扩束镜原理(英文)
发表于 2008-12-14 23:34:18 | 显示全部楼层 |阅读模式
光扩束镜原理(英文); t  H1 n" o3 }# q2 i* `4 c
2008-09-12 08:371 A: s1 Y6 ^7 g; F/ B
The most common type of beam expander is derived from the Galilean telescope which usually has one negative input lens and one positive output lens, as shown in Figure 1. The input lens presents a virtual beam focus at the output. For low expansion ratios (1.3-20´), the Galilean telescope is most often employed due to its simplicity, small package size, and low cost.
2 j8 [( N! L- @7 g9 d- T5 a. G
% L" }3 }8 y8 a5 W  Y& F4 DFigure 1: Diagram of a beam expander
2 ^  m( Q; y$ {  a* i) f# TAs shown in Figure 1, the lens M3 focuses the laser beam onto the front focus plane and the new beam waist w¢0 and divergence angle q¢ can be represented as( w0 D% F3 Y- A
  u4 m. A  `9 O- Y. S& R2 a: K
) I% j8 b9 l7 C; Q6 G( L                                                       (1). l0 {" _6 U: R6 n; Z$ g5 `$ }
and
( q. i# g+ ^, u4 M& {$ x) n- L
7 y1 J) ^6 s1 E5 @, ?& G  |: z; H                                                              (2)
; {' V, p% E0 J* K( N8 z: U( O, t2 E9 z: e
                                       (3)& @* }( I5 b9 e
where w(l) is the radius of the beam entering the lens M3, l is the distance between the lens M3 and the beam waist w0 from the laser generator, and f3 is the focal length of the lens M3.
8 u. _. B- k4 X$ ySince w0¢ lies on the back focus plane of the lens M4 with a longer focal length, f4, the Gaussian beam with a beam waist w¢0 will be collimated by the beam expander. The collimation ratio of the beam expander for a Gaussian beam is as follows
* Y1 |- k8 O" j# p% ?/ {7 t# ^1 D5 g/ G9 R) f" b2 c; u
                (4)% L5 l+ g7 K% z$ c- c
where T1 = f4/f3. The beam waist w²0 and divergence angle q² after the beam expander are* O+ M5 Y$ {( f
4 L0 A) g" I; u* u8 Q( f% N3 g                          (5)2 p5 s5 @0 b: i# J- R9 S: e- [
and
* [: J" v1 T5 \- _3 k0 t
- D8 `! |9 e9 W4 e4 [, e" P- z                               (6). V' i6 H3 m2 e/ Y
Substituting Equation (1) into Equation (5), the following expression can be obtained
. U; s7 M/ w1 [2 q8 U& X' Q
( z8 H) V9 X4 t' Z" F                            (7)
5 @8 x% q  I; h- \  h- r. uFrom Equations (4)-(7), it is concluded that the beam expansion ratio and the collimation ratio for a Gaussian beam depend not only on the specifications of the beam expander, but also on the laser beam parameters as well as the positions of the optical lenses.
% c  l! q; W! [0 _. B- T0 SThe function of a beam expander is to reduce the divergence angle of laser beams and thus make the focused beam diameter smaller.
GMT, 2025-10-16 , Processed in 0.027975 second(s), 22 queries .
