一种双通道窄带滤光片的设计与制备
/ s, _) _" l4 _0 S* v- G王济洲 熊玉卿 刘宏开 陈焘兰州物理研究所,表面工程技术国家级重点实验室,甘肃兰州730000摘要:对光子晶体技术在滤光片设计中的应用进行了可行性研究。利用一维光子晶体进行了双通道窄带滤光片的设计,并利用离子束辅助沉积方法进行了滤光片的镀制。同时研究了膜层的误差对滤光片光谱性能的影响,表明其敏感层主要是缺陷层。实验结果表明,运用光子晶体概念进行双通道窄带滤光片设计是可行的。2 [, o7 q1 W: g
3 `; y8 H4 R) p `2 T$ x) R# ?* G
KeyWord:one-dimension photonic crystal;dual-band filter; optical thin film! q7 L, E, H2 b1 H
6 Y6 b) R) l0 w9 l4 N, p关键词:一维光子晶体 双通道滤光片 光学薄膜1 L% {, s! P P" \( P8 r
& s$ @! v* T+ Q
分类号:O472.8[著者标引]文献标识码:A文章编号:1006-7086(2008)01-0037-04+ H1 W9 N) ~1 U* y7 D! R
DESIGN AND PREPARATION OF A DUAL-BAND OPTICAL FILTER WANG Ji-zhou, XIONG Yu-qing, L]U Hong-kai, CHEN Tao National Key Lab of Surface Engineering, Lanzhou Institute of Physics, Lanzhou 730000, China
/ f9 n. L6 ?2 M2 O) uAbstract:The possibility of designing optical filters using photonic crystals technique was studied in this paper. A dualchannel optical filter was designed using photonic crystal concept and prepared by/on Beam Assisted Deposition (IBAD). The influence of thickness error of each layer to optical character was also discussed, and the result shows that the most sensitive layer is defect-layer. So it is possible to design dual-channel filters using one-dimension photonic crystals concept.
/ @ t7 D4 g, |# U1 O" C% ]" H! Q
KeyWord:one-dimension photonic crystal;dual-band filter; optical thin film |
您需要 登录 才可以下载或查看,没有帐号?注册
x
