发表于 2009-3-4 23:24:58
显示全部楼层
Standard Test Method for
0 A9 n; O1 d% s8 c+ \# KSolar Absorptance, Reflectance, and Transmittance of Materials Using Integrating Spheres1 / Y2 n5 z, ~! N3 {
This standard is issued under the fixed designation E 903; the number immediately following the designation indicates the year of original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A superscript epsilon () indicates an editorial change since the last revision or reapproval. |
