1199| 5
[原创] Design of optical interference coatings 1992 |
gds 该用户已被删除
[/free]【文章名】 Design of optical interference coatings 1992
【PAGE】 pp.2-7 【AUTHOR】 Alfred J. Thelen, Ingenieurbuero Thelen, Schmitten, Federal Republic of Germany. 【ABSTRACT】 The current two major non-numerical design methods, equivalent layers and polynomial synthesis, are reviewed and compared. The equivalent layer method works well when only a small number of fixed refractive indices is available. This is the case when the coating is manufactured by evaporation. Polynomial synthesis generates a priori better designs but does not allow predetermination of refractive indices. So, for evaporation, the designs have to be translated from many refractive indices to a few. This process generally downgrades the design. This translation is not necessary when sputtering or chemical vapor deposition is being used. Here, in-between refractive indices can easily be generated by mixing or flip-flopping. As a consequence, superior designs can be implemented. [free]
购买主题
本主题需向作者支付 50 RMB金钱 才能浏览
发表于 2006-1-6 13:41:53
显示全部楼层
发表于 2005-12-29 21:07:58
显示全部楼层
