查看: 1080|回复: 1
[转贴] 采用柔性ITO导电膜制备聚合物分散液晶PDLC光开关
gds 该用户已被删除
发表于 2007-11-23 18:13:22 | 显示全部楼层 |阅读模式
+ j9 d: }" a( M. Q, T董大明 刘官元 张占山 张雪峰 晋伟 阙耀华内蒙古科技大学理学院,内蒙古包头014010摘 要:在不同的配比下,采用相分离的技术,将柔性ITO导电薄膜、单组份紫外光学固化胶NOA65、联苯氰胺向列液晶混合物E7,制备成PDLC光开关的过程和方法进行了阐述,给出电光特性的测试结果和分析,得到最佳配比的阈值电压为12.6 V,透过率为87.6%,对比度为71.8.[著者文摘]
* z  n1 ^! N+ z2 D' n& w- \, ^
3 ^4 H+ \, i& d  a: d关键词:ITO PDLC 光开关 电光特性5 T" ^- _  [# u0 x/ }% d" i2 U
分类号: O753.2[著者标引]文献标识码:A文章编号:1004-9762(2006)01-0089-03栏目信息:  g0 P% g/ v1 D
相关文献:主题相关 全文快照
; q' F3 s$ ^7 y$ b
, E) L9 M$ c) e( z: kProducing polymer-dispersed liquid crystal (PDLC) optical switch with flexible ITO elcetric membraneDONG Da-ming, LIU Guan-yuan, ZHANG Zhan-shan, ZHANG Xue-feng, JIN Wei, QUE Yao-Hua Mathematics and Physics School, Inner Mongolia University of Science and Techmology, Baotou 014010, ChinaAbstract:At the different compounding ratlo,the process and method to produce PDLC optical switch were introduced that uses ITO electric membrane,ultraviolet optical solidified glue (NOA65) and bipheny cyanamid liquid crystal admixture E7 while taking the technique of phase separation. The test results and analysis about the electro-optic specifications were obtained. The threshold voltage for the best compounding ratio is 12.6 V;the transmittance is 87.6,and the contrast is 71.8.[著者文摘]
看看!!!
GMT, 2025-10-17 , Processed in 0.024407 second(s), 22 queries .
