查看: 5661|回复: 5
[文献求助] 求文献:二极管抽运的低阈值Nd3+:KY(WO4)2 1072nm激光器
发表于 2007-11-19 22:10:44 | 显示全部楼层 |阅读模式
二极管抽运的低阈值Nd3+:KY(WO4)2 1072nm激光器,林浪;! u1 A* u/ q; b  L$ j+ x# Z
Chinese Optics Letters,2007第5卷第10期582页
gds 该用户已被删除
类似的饿
8 e, i% |" D6 u7 l$ x( g! F. B/ t, R  e: ^
LD端泵Nd:GdVO4/KTP腔内倍频绿光激光器的研究
7 L4 ~( z$ _0 b# F林浪[1] 陈振强[1,2] 王如刚[1] 张戈[3] 李真[1] 陈义红[4][1]暨南大学光电工程系,广东广州510632 [2]暨南大学光光电工程研究所,广东广州510632 [3]中科院福建物质结构研究所,福建福州350002 [4]广州安特激光技术有限公司,广东广州510730摘 要:报道了半导体激光二极管(LD)端面泵浦Nd:GdVO4晶体,KTP晶体腔内倍频实现了531.7nm连续波绿色激光器.采用简单、紧凑的平凹直腔结构,当注入泵浦的功率为12W时,得到了372mW的稳定绿光输出,光一光转换效率为3.1%.功率稳定性半小时内优于±1.2%.[著者文摘]# W* y0 v1 l9 W# }& W6 F4 c6 r9 d
% ]6 D# a& d/ h6 p& @3 ~关键词:半导体激光二极管 Nd:GdVO4 腔内倍频 相位匹配角! {: `  x; D! X  a3 O0 f5 Y
分类号: TN248.1[著者标引]文献标识码:A文章编号:1000-9965(2007)01-0070-04栏目信息:
4 A+ `( a8 M* T9 O# Y! B/ k5 v相关文献:主题相关 全文快照   1 |9 N" S8 M8 o8 m
% T& ^- i% t" ^6 DStudies on LD end-pumped Nd: GdVO4/KTP Intra-cavity-frequency-doubling Green LaserLIN Lang, CHEN Zhen-qiang, WANG Ru-gang, ZHANG Ge, LI Zhen, CHEN Yi-hong 1. Department of Optoelectronic Engineering; 2. Institute of Optoelectronic Engineering, Jinan University, Guangzhou 510632, China; 3. Fujian Institute of Research on Structure of Matter, The Chinese Academy of Science, Fuzhou 350002, China; 4. Ante Laser (Guangzhou) Co Ltd, G uangzhou 510730, ChinaAbstract:An LD end-pumped Nd: GdV04, KTP Intra-cavity frequency doubling Green Laser at 531.7 nm is reported. Using simple compact fiat-concave cavity, 531.7 nm continuous green laser is obtained by 1 063.4 nm Intra-cavity frequency doubling with KTP crystal. When the incident pump power is about 12 W, the stable output power of 372 mW was achieved at 531.7 nm. The optical-to-optical conversion efficiency is up to 3. 1% and the power fluctuation is less than ± 1.2% for 0. 5 h.[著者文摘]
$ Y, ~* z8 W8 Z
2 U9 g- p: p: p/ M5 K" m) s6 b; }Key wordsiode Laser; Nd: GdVO4 ; Intra-cavity-frequency-doubling; phase-matching angle
QQ
发表于 2009-2-24 20:30:27 | 显示全部楼层
路过。
嗯,虽然路过。1 B8 v# a& a2 ^+ }  t* f( t
还是厚道的顶一下
3 `: L% {$ E& M5 I---------
; _8 z1 J: f1 q% g6 p淘宝
QQ
发表于 2009-5-28 02:45:43 | 显示全部楼层
强
在下对你的景仰之情有如滔滔长江之水,连绵不绝.
3
发表于 2009-8-27 15:05:49 | 显示全部楼层
现在真的要对激光器的方向进行研究下了。
QQ
发表于 2010-2-4 22:04:42 | 显示全部楼层
额~
真不容易上来了,今天这个破网老调。回个帖试下~
GMT, 2026-10-24 , Processed in 0.092066 second(s), 26 queries .
