查看: 2785|回复: 1
[原创] 化学法制备的HfO_2薄膜的激光损伤阈值研究
gds 该用户已被删除
发表于 2007-11-18 01:15:21 | 显示全部楼层 |阅读模式
% ^7 r9 Q& W1 y" X1 E6 s9 p2 {
# w  y7 l: v$ M, S7 a4 `( D  O ; J% y/ `+ F' r$ z$ l! x
0 }2 q4 Q/ f7 I/ @/ o, x: U【英文篇名】 Laser-induced damage threshold of hafnia thin films with chemical method
# c3 a% ~4 T0 n1 G% e$ l# e【作者中文名】 沈军; 罗爱云; 吴广明; 林雪晶; 谢志勇; 吴晓娴; 刘春泽;
# i  Y. n0 e, D, n4 y5 _/ r7 x【作者英文名】 SHEN Jun; LUO Ai-yun; WU Guang-ming; LIN Xue-jing; XIE Zhi-yong; WU Xiao-xian; LIU Chun-ze (Pohl Institute of Solid States Physics; Tongji University; Shanghai 200092; China);
  |! |& l7 ~" {' \( X1 \0 @【作者单位】 同济大学波耳固体物理研究所; 同济大学波耳固体物理研究所 上海;
$ A3 b7 `9 W  }" ]+ Q+ F4 o$ [) A【文献出处】 强激光与粒子束, High Power Laser and Particle Beams, 编辑部邮箱 2007年 03期  6 \1 ]  ]6 Q  n- ^! t: N
期刊荣誉:中文核心期刊要目总览  ASPT来源刊  中国期刊方阵  CJFD收录刊 & @- P. P9 e6 m5 W8 a3 T4 I, U; j9 z% m
【关键词】 HfO2薄膜; 热处理; 紫外辐照; HfO2-Al2O3复合薄膜; 激光损伤阈值; ! i; ]9 [. O9 `6 a8 a' ~
【英文关键词】 HfO2 thin films; Heat treatment; UV irradiation; HfO2-Al2O3 composite films; Laser-induced damage threshold; ) L* Q$ `6 X& f
【摘要】 采用化学法制备了HfO2介质膜,研究了热处理、紫外辐照以及Al2O3复合对HfO2介质膜激光损伤阈值的影响。采用红外光谱(FTIR)和X射线衍射仪对薄膜进行了表征,并用输出波长为1.064μm、脉宽为10 ns的电光调Q激光系统测试薄膜的激光损伤阈值。实验结果表明:采用150℃左右的温度对薄膜进行热处理可以提高薄膜的激光损伤阈值,所获得的薄膜的激光损伤阈值高达42.32 J/cm2,比热处理前的激光损伤阈值提高了82%;无机材料Al2O3的适量添加能够提高薄膜的激光损伤阈值,其中HfO2与Al2O3的最佳质量配比约为95∶5;另外,对薄膜进行适当的紫外辐照也可改善HfO2薄膜以及HfO2-Al2O3复合薄膜的抗激光损伤性能。紫外辐照对提高HfO2-Al2O3复合薄膜的激光损伤阈值效果尤为显著,辐照40 min后的激光损伤阈值达到44.33 J/cm2,比紫外辐照前的激光损伤阈值提高了90%。 ' M( V( |6 t7 ]9 f
【英文摘要】 HfO2 thin films were prepared with chemical method.The influences of heat treatment,UV irradiation and addition of inorganic Al2O3 on laser-induced damage thresholds(LIDT) of HfO2 thin films were studied.HfO2 thin films were characterized by FTIR and X-ray diffraction.And 1-on-1 laser-induced damage threshold tests on HfO2 thin films and HfO2-Al2O3 composite films were carried out with a Q-switched Nd:YAG high power laser at 1 064 nm with a pulse width of 10 ns.The research results showed that the LIDT of t... , H# g# E- q4 _9 @4 m+ C
【基金】 国家自然科学基金重点资助课题(21033040);; 国家863计划项目资助课题(2002AA84052);; 上海科委纳米专项资助课题(0552nm08);; 教育部跨世纪优秀人才计划资助课题;; 上海市重点学科建设资助课题(02SL001);; 上海市科技攻关计划资助课题(055211010)
6 x! M, r! }0 l) V0 A2 Y【DOI】 CNKI:ISSN:1001-4322.0.2007-03-012
QQ
发表于 2009-8-8 15:35:52 | 显示全部楼层
你好啊,过来看看!呵呵
GMT, 2026-4-30 , Processed in 0.056118 second(s), 26 queries .
