我处现有一台日本昭和900光学镀膜机转让,以下是机器的配置:2 [$ M- g, J) ]/ w
Showa Optical Coating Machine Model: SGC-22SA-IAD
+ G) o8 }8 O1 K" h Year made: 2001 4 x& V2 X5 o; v& w8 t8 l4 X1 A
System area coverage 15 m2
: D1 Y% t8 o) Q" B# k, O2 Z; fChamber size: 900 mm0 O: f& I9 x8 Y1 [) q
Low vacumm system: KP3000 + Rotary Pump+ULVAC PRC-012AS D. d& c. T3 c: L2 S2 I
High vacumm system: SHOWA SHINKU SFD-22C oil Diffusion Pump. & _# z9 U5 z; i: z! R
Polycold R2000 series0 N+ R* g7 h- M( \" L: L( @" u% J7 v" ]
One E-Beam Gun with 12” diameter ring crucible, one RH .
' I. S6 ^6 ^* @ {$ PJEOL JST-10F EB-Source Power Supply
5 w Z! n3 C3 gOptical monitoring system. Wavelength monitoring range 300 nm ~ 2000 nm.; }6 ^8 R* p" m! D$ u& J
Reflection type. OMS chip changer over 30 testing chips.
% q( J8 u- E8 V6 ?: C/ b$ x8 K, J
/ S/ d! M: t: k; P% Z8 a联系邮箱:fixcoater@eyou.com |
