查看: 917|回复: 0
[原创] 假想层”在Needlee法膜系设计中的应用
发表于 2007-8-22 02:49:12 | 显示全部楼层 |阅读模式
. q4 D* F+ a, b7 J' g) n     ( P& y& [% g3 r" @# t; M
) `0 Q5 `% D$ l! a
7 o; b2 b; J! _0 w
. j6 W5 |5 W- L7 x/ W% n
【英文篇名】 Application of Virtual Layer in the Needle coating design
" B  o* j9 }. \) ^【作者】 杨开勇; 龙兴武; 黄云; 李晓红;
, y3 e$ D( Z* P( L8 d【英文作者】 YANG Kai-yong; LONG Xing-wu; HUANG Yun; LI Xiao-hong(Department of Optoelectronic Engineering; College of Optoelectronic Science & Engineering; National University of Defence Technology; Changsha; China);
% ?, M5 `7 T" Z! ^【作者单位】 国防科技大学光电科学与工程学院光电工程系; / \" R0 H. r2 D
【刊名】 激光杂志 , Laser Journal, 编辑部邮箱 2006年 05期  / J6 U4 W4 p* S. l. B) K2 o$ n  W
期刊荣誉:中文核心期刊要目总览  ASPT来源刊  中国期刊方阵  CJFD收录刊
6 _4 ^  e7 n, S/ L* z4 D【关键词】 薄膜光学; 膜系设计; Needle法; 假想层;
; ?! S* e) s4 l: F0 n: i' U【英文关键词】 film optics; coating design; Needle method; Virtual Layer; 2 u, S% [8 p0 y! k8 N0 C* P4 ?2 @$ k
【摘要】 Needle法是一种强大的膜系设计方法,它的突出特点是不依赖于初始膜系的给定,几乎对各种膜系设计目标都能给出比较令人满意的设计结果。但它的物理模型不够清楚,很难从直观上理解。通过在Needle法的推导过程中引入“假想层”的概念,使Needle法的整个推导过程清楚明了、容易理解,改进后的Needle法依然保持了它原来的各种优点。最后用两个设计实例说明了这种改进的有效性。
; V/ R: }. Q2 s" R9 _- S; s【英文摘要】 The Needle method is a powerful coating design method,and its prominent characteristic is that the output doesn't depend on the given initial coating and it can be used to design almost all kinds of coatings.But the defect is that its physical model isn't clear enough to be understood easily by a new comer.By introducing the idea of "Virtual Layer" in the Needle method,the whole deduction process is clear and easy to understand.The improved Needle method preserves all the primitive strongpoints.Finally,two ... $ k6 c4 }  L  |* V* M
【DOI】 cnki:ISSN:0253-2743.0.2006-05-014
GMT, 2025-10-17 , Processed in 0.025437 second(s), 23 queries .
