硅太阳电池用UV/IR截止滤光膜系设计杨文华[1] 李红波[2] 解光军[1] 梁齐[1][1]合肥工业大学理学院,合肥230009 [2]上海空间电源研究所,上海200233摘 要:根据光学薄膜原理,编制出计算机程序。在太阳电池封装玻璃的上、下表面分别设计出红外(IT)截止的带通滤光膜系A|[1.05(LMHML)](LMHML)6[1.15(LMHML)]1.15L|G和紫外(UV)截止的带通滤光膜系G|H/2LH/2|。透射曲线表明:这两种带通滤光膜系对于不同波长的光有着很好的选择性透射,IR截止滤光膜系能够使波长大于1120nm的大部分光在到达电池表面前就被反射,UV截止滤光膜系能够使得波长小于350nm的光在到达电池表面前几乎全部被反射掉。同时,350nm〈A〈1120nm的光的入射几乎不受影响,加权平均透射率为97.49%。[著者文摘]
0 h& y) c) M2 R4 `9 F( y
: B+ O( {3 o3 R关键词:硅太阳电池 UV截止滤光膜系 IR截止滤光膜系 透射曲线 加权平均反射率
3 J& ^) F( G, p! L: I8 V分类号: TM914.4[著者标引]文献标识码:A文章编号:0254-0096(2007)03-0257-06栏目信息:+ V6 i1 r$ y/ b3 p4 n
相关文献:主题相关 全文快照 8 q- V# W R/ d% G/ {+ y2 z% f- Y
+ @5 [: @" ~! B
THE DESIGN OF UV/IR CUT-OFF FILTER FOR SILICON SOLAR CELLSYang Wenhua, Li Hongbo, Xie Guangjun, Liang Qi 1. School of science, Hefei University of Technology, Hefei 230009, China ; 2. Shanghai Space Power Institute, Shanghai 200233, ChinaAbstract:According to the theory of optical film, a computer program was designed. The IR cut-off filter of A|[1.05(LMHML)](LMHML)6[1.15(LMHML)]1.15L|G G on the top surface of encapsulation glass and the UV cut-off filter of G|H/2LH/2| on the rear surface of encapsulation glass for silicon solar cell were obtained. Plotted transmission curves for IR and UV cut-off filter showed that: the IR cut-off filter and UV cut-off filter both have good selective transmission for incidence light. Most of the light( λ〉1l20nm) is reflected by IR cut-off filter, most of light (λ 〈 350nm) is reflected by UV cut-off filter, and all of the light (350nm 〈 λ〈 1120nm) is almost transmitted to the solar cell. In the range between 350nm and 1120nm, the weighted transmission coefficient of light is 97.49%.[著者文摘]5 f) w4 L6 v, \( T$ o
- q9 \2 C2 Y; j/ S* l+ N* H. S, O
Key words:silicon solar cell; UV cut-off filter; IR cut-off filter; transmission curve; the weighted transmission coefficient |
