查看: 1048|回复: 1
[原创] 基底对光学薄膜弱吸收测量的影响
发表于 2007-8-9 23:58:23 | 显示全部楼层 |阅读模式
基底对光学薄膜弱吸收测量的影响李霞[1,2] 贺洪波[1] 赵元安[1] 范正修[1][1]中国科学院上海光学精密机械研究所,上海201800 [2]中国科学院研究生院,北京100039摘 要:对表面热透镜技术测量光学薄膜弱吸收低频调制时不同基底对测量的影响进行了理论分析。用Lambda-900分光光度计测量了K9和石英基底的Ti3O5单层膜的吸收值,将该组样品作为定标片;用表面热透镜装置分别测量了BK7和石英空白基底及HfO2,ZnO两组不同基底不同厚度单层膜样品的吸收。通过分析比较同一工艺条件下镀制的不同基底薄膜样品用与其同种和不同种基底定标片定标测量的结果,表明在低频测量时需要用与测量样品同种基底的定标片定标;不同厚度样品的测量结果表明,在不能严格满足热薄条件时,测量结果需引入修正值。[著者文摘]
8 N2 ]( H/ \7 ?) n$ `( W3 R3 s* h* B  ]0 @6 J/ n
关键词:表面热透镜技术 薄膜 弱吸收 定标 基底
; y6 ]9 o# Y4 S$ K% y1 A  P& j分类号: O432.2[著者标引]文献标识码:A文章编号:1001-4322(2007)02-0257-05栏目信息:ICF与激光等离子体
( J% Q3 M0 n5 J5 C2 U4 c: `4 r" j相关文献:主题相关 全文快照   ; e3 V) l( ~0 F- ?' b. r, J
0 P0 p- Q; g9 ], n: s- R
Substrate effects on measurement of weak absorption of optical thin filmsLI Xia , HE Hong-Bo , ZHAO Yuan-an , FAN Zheng-xiu 1. Shanghai Institute of Optics and Fine Mechanics, Chinese Academy of Sciences, Shanghai 201800, China; 2. Graduate School of Chinese Acadmy of Sciences, Beijing 100039, ChinaAbstract:The substrate effects on the measurement of weak absorption of optical thin films at low frequency are analysed in theory. The absorptions of different thin films, including single-layer HfO2 and ZnO thin films with different thickness, on two substrates (BK7 and silica), as well as absorptions of blank substrates have been measured by surface thermal lensing technique. As a calibrated sample, the absorptions of singal-layer Ti3O5 thin films were measured by Lambda-900 spectrometer. The experimental results show that the substrate of standard film is the same as the substrate of sample in calibration for low measurement is necessary. After considering the influence of film thickness,the correction would be possible.[著者文摘]2 G  i$ n8 }; k
/ ^2 G4 h; p. A* o! Z2 ^1 q' W
Key words:Surface thermal lensing technique; Thin films; Weak absorption; Calibration;
19
3 F& U7 w+ ]- {$ V# u& v- X不错
- S! d5 G, W/ K; V/ M3 x# M!1
GMT, 2025-10-16 , Processed in 0.027109 second(s), 24 queries .
