查看: 939|回复: 0
[转贴] Si基片上的镧钙锰氧巨磁阻薄膜材料的微结构分析
发表于 2007-7-26 01:05:07 | 显示全部楼层 |阅读模式
Si基片上的镧钙锰氧巨磁阻薄膜材料的微结构分析' Y9 G9 [5 _/ j6 b/ J
荆丽华 王立峰 张巍巍 朱明东南大学物理系,江苏南京211189摘 要:采用溶胶-凝胶法在Si单晶上制备了定向生长的巨磁阻锰氧化物La0.8Ca0.2MnO3(LCMO)薄膜样品,并用X射线衍射(XRD)、偏光显微镜及原子力显微镜(AFM)对薄膜样品的微结构进行了分析。实验发现在某些特定的条件下LCMO薄膜形成网格结构的现象,并尝试根据分形理论用计算机程序对这种网格现象进行了形貌模拟。[著者文摘]* B6 S6 S9 i7 d, Q
2 P& b5 m# ?9 A% u- b8 h( X
关键词:钙钛矿 镧钙锰氧 微结构 分形
( k. U5 J* e) B& ^3 }8 I1 w& Q, Q; s; V分类号: O484.5[机标]文献标识码:文章编号:栏目信息:工艺·试验
2 D1 T; M% J0 g0 F9 D相关文献:主题相关 全文快照   % K% f. p% H$ i7 a( U  r
+ `, n$ Q/ ?; r1 T; h  M; }
The Analysis on Microtrucure in Perovskoyes Colossal Magnetoresistance Thin Films on the Si(100) WaferJing Lihua, Wang Lifeng, Zhang Weiwei, Zhu Ming Department of Physics, Southeast University, Jiangsu Nanjing 211189Abstract:Using Sol - Gel method, the epitaxial perovskite La0.8Ca0.2MnO3(x = 0.2) thin film was prepared on the Si(100) wafer. The X - ray Diffraction (XRD), Polari - microscope,and Atomic Force Microscope (AFM) were used to analyze the microstructure and the figure of the film. It was found that the percolation structure would form under certain condition. The thin film figure and made some interpretations were simulated by fractal method.[著者文摘]/ C. |# q% E/ X, g) m5 A8 Z
) Z/ l2 Z% E4 E2 \- N' l+ |
Key wordserovskites;La0.8Ca0.2MnO3; Microstucture Fractal
GMT, 2025-10-16 , Processed in 0.030808 second(s), 24 queries .
