查看: 868|回复: 0
[转贴] 模具钢表面连续激光沉积TiN类薄膜的研究
gds 该用户已被删除
发表于 2007-7-4 00:22:45 | 显示全部楼层 |阅读模式
模具钢表面连续激光沉积TiN类薄膜的研究葛柏青 段来根 郎荣兴常州机电职业技术学院模具技术系,江苏常州213164摘 要:利用波长为10.6μm的CO2连续激光诱导化学气相沉积的方法,在模具钢基体上沉积TiN类薄膜。采用XRD、OM、SEM、EDS等手段分析薄膜的组织和相结构。实验表明,当激光功率为600W,扫描速度为2mm/s时,通过H2、N2和TiCl4之间的化学反应,在模具钢表面获得了均匀致密的枝晶组织,其显微硬度最高可达2500HV。[著者文摘]
" `) c9 X1 n9 X; X. g
9 V9 f, v% i9 T* m7 u关键词:模具钢 激光化学气相沉积 薄膜4 D# c5 e- ^+ Z, Q, o
分类号: TG156.99[著者标引]文献标识码:A文章编号:1673-4971(2007)01-0007-03栏目信息:试验研究% _5 N: I$ T9 ?0 w( u5 X
相关文献:主题相关 全文快照
& H2 _, P; r: R  r/ @! W; a) x' V: W; D) l# w
Study on Continuous Laser Deposition of TiN Thin Films on Die Steel SubstrateGE Bai-qing, DUAN Lai-gen, LANG Rong-xing Changzhou Institute of Mechatronic Technology,Changzhou Jiangsu 213164, ChinaAbstract:The TiN thin films were produced on die steel substrate by wavelength of 10.6 m CO2 continual laser chemical vapor deposition (LCVD). The microstructures and morphology of the TiN thin films were characterized by X-ray diffraction (XRD), optical microscope (OM), scanning electron microscope (SEM), and energy disperse spectrometer (EDS). The results indicated that, only when the laser power is 600 W and scanning velocity is 2 mm/s, through the reaction of H2, N2 and TiCl4, the TiN films were deposited on die steel substrate by LCVD. And they have dense dendritic structure. Its microhardness is 2500 HV.[著者文摘]
! N. v7 |6 s8 x2 d& s; N
& U( e7 |8 L- dKey wordsie steel; LCVD; Thin films
GMT, 2025-10-16 , Processed in 0.025043 second(s), 23 queries .
