用于强激光系统的取样光栅减反射膜的研究
2 J9 }! m& L8 r( Y- n. j刘 全,吴建宏
1 ~9 I' V7 |$ d, }(苏州大学 信息光学工程研究所,苏州 215006)
: R& m1 r1 p+ u2 H9 K摘要 使用严格的耦合波理论分析了强激光系统镀sol-gel减反膜的取样光栅(BSG)特性,详细的分析了仿形膜和平面膜的减反情况和取样效率的变化。结果表明,镀平面膜是一种可行的技术方案,裸光栅的深度d是12nm时,膜厚dp为60nm,即光学厚度为1/4波长:d+dp=72nm。此时的取样效率为0.241‰。或者保证取样效率是1‰,则有dp=60nm, d=25nm;与未镀膜的裸光栅相比,采用文中所述方法设计的镀膜光栅有很好的减反增透效果,具有良好的应用前景。7 y8 d! u& }, \+ W
' p. g/ s) {2 `! Y- h9 i关键词 取样光栅;严格耦合波理论;减反膜;衍射效率
2 b$ t! C, A5 W, t( j6 y7 w( s中图分类号 O436.1 O484 文献标识码 A
, v1 A5 C7 Q) R! n$ @) n$ C; M: _* ]2 x
Rigorous Coupled-wave Analysis of Beam Sampling, ^6 h0 ]9 V) q0 S5 p% V
Grating with AR coating
& e" J( b' r4 P% _0 b" u: rLIU Quan,WU Jian-hong
4 G( M4 W8 j* @3 H# S7 T(Information Optics Engineering Institute, Soochow University, Suzhou 215006, China)! O8 u( m+ E+ x- x6 x0 Z6 Z) x
Abstract The characteristics of the BSG with anti-reflection coating(sol-gel), which is employed in the inertial confinement fusion(ICF) system, have been analyzed by using the rigorous coupled-wave theory. The anti-reflection characteristics of the BSG with conformal AR coating and planarizing AR coating have been discussed in detail. The results show that the planarizing AR coating is remarkable.
M$ E+ d2 \' {* C
" r8 q; r; G% R. ]3 QKey words beam sampling grating(BSG); rigorous coupled-wave theory ; anti-reflective coating; diffraction efficiency |
您需要 登录 才可以下载或查看,没有帐号?注册
x
