Optical Limitation induced by Gold Clusters. 1. Size Effect
7 l+ E+ Z( b8 {Lionel Francüois, Mehran Mostafavi,* and Jacqueline Belloni
6 U) e. h' C2 ?, f7 cLaboratoire de Chimie Physique, UMR 8610 CNRS, UniVersite´ Paris-Sud, 91405 Orsay, Cedex, France2 I* j3 s0 T6 i6 m7 e! e: o) M
Jean-Francüois Delouis and Jacques Delaire
3 ~# m5 k- }; V" F: S9 JLaboratoire de Photophysique et Photochimie Supramole´culaires et Macromole´culaires, UMR 8531,
8 v$ a" u) W. p- t6 C6 \8 OEcole Normale Supe´rieure de Cachan, 94235 Cachan Cedex, France% k6 x4 B, u7 E" ~% M x# ?: ^
Patrick Feneyrou
" f* Z) I+ P2 f W9 rLaboratoire Central de Recherches, Thomson-CSF, Domaine de CorbeVille, 91404 Orsay Cedex, France
/ }& P, l4 T! b( IReceiVed: December 20, 1999; In Final Form: March 8, 2000
6 D2 S9 Q g; m E5 A- y' X' {6 tThe nonlinear optical response of gold particles (with 2.5, 9, or 15 nm radius) prepared by ç-radiolysis in
/ k7 C4 x- Z$ |& C" Awater solution and stabilized by poly(vinyl alcohol) is size-dependent. The 2.5 nm clusters do not limit light
% ~& I7 z9 `8 r% etransmission even at very high fluence of nanosecond laser pulses, while the larger clusters strongly limit the2 S& Q2 D: d% ^1 a% t; v1 C
laser beam transmission at 530 nm. The threshold of limitation and the amplitude depend on the size of the
1 U; y ?! B4 p" ~3 Rparticles. The rise of the optical limiting effect is measured by picosecond laser spectroscopy. For the largest
! J; A4 c( [4 |+ {( cparticles, it lasts 1 ns. The limitation effect is attributed to large light-scattering centers induced by the pulse8 C5 }/ A( ?( C+ j9 g e3 q
around the initial particles. |
