氮离子束能量对光伏新材料氮化碳薄膜的影响姜维 周之斌 崔容强 罗培青 刘志刚 窦晓鸣上海交通大学物理系太阳能研究所,上海200240摘 要:将碳基材料应用于太阳电池半导体器件的研究已经在国内外得到重视和开展。采用离子束溅射反应沉积技术,在P型绒面硅和P型硅基片上沉积出用于制备太阳电池的氮化碳薄膜(a-C:N)。ⅠD/ⅠG比率,ⅠS/ⅠG比率是研究氯化碳薄膜微结构的重要拉曼参数,对这些参数随氮离子束能量的变化进行了研究。能量散射光谱(EDS)和透射电子显微镜(TEM)测试显示随氮离子束能量增大。薄膜中氮原子含量下降,团簇尺寸大幅下降,非晶网络中团簇分布也趋于均匀。用真空热蒸镀工艺在氮化碳/硅异质结的氮化碳薄膜表面镀上一层半透明的铝薄膜,测得AM1.5标准光照下的开路电压随氦离子束能量的增加而增大。[著者文摘]
) |8 H: V5 Y0 w
1 K- J# v6 G. `5 z( w关键词:氮化碳 离子束溅射 拉曼 TEM EDS 开路电压
( Q7 O9 s |/ Z6 u8 S分类号: TM914.4[著者标引]文献标识码:A文章编号:1002-087X(2006)11-0921-04栏目信息:研究与设计
% u- g; Y* u& G4 e- Y0 l9 }相关文献:主题相关 全文快照 + ~" A8 l: z: Y. X; x% k
3 p( O$ `% H9 ?9 i) `
Influence of nitrogen ion energy on photovoltaic new material carbon nitride filmsJIANG Wei, ZHOU Zhi-bin, CUI Rong-qiang, LUO Pei-qing, LIU Zhi-gang, DOU Xiao-mingSolar Energy Institute, Department of Physics, Shanghai Jiaotong University, Shanghai 200240, ChinaAbstract:Carbon-based material has been attempted as a semiconductor in photovoltaic solar cell. Carbon nitride (a-C:N) thin films also have been deposited for solar cell applications. Carbon nithde films were deposited on p-type textured Si and p-type Si substrates by ion beam sputtering technique. The dependence of Ⅰ D/ⅠG ratio and ⅠS/ⅠG ratio on nitrogen ion energy is discussed, which are the important Raman parameters in studying the structure of carbon nitnde films. The results of EDS and TEM indicate that atomic concentration of nitrogen and the sizes of clusters decrease, and that the thin film morphology becomes more uniform in the amorphous mixture with the increasing nitrogen ion energy. A sub-transparent AI film was evaporated on the carbon nitride films of carbon nitride/Si heterojunctions by heat evaporation technique. Under illumination of AM 1.5 standard light source, the open-circuit voltage of Al/a-C:N/p-Si increases with the increase of nitrogen ion energy.[著者文摘]- J# I- y6 @& u4 P6 I/ e! {
4 R9 D. }) \4 Y/ M+ c, U. H/ n5 G
Key words:carbon nitride; ion beam sputtering; Raman; TEM; EDS; open-circuit voltage |
