查看: 2587|回复: 0
[转贴] Coating for a Fabry-Perot Interferometer
gds 该用户已被删除
发表于 2007-5-14 21:28:13 | 显示全部楼层 |阅读模式
This coating was presented in the paper "Optical coating without phase dispersion for a Fabry-Perot Interferometer", by F. Lemarquis and E. Pelletier, Applied Optics, Vol. 35, No. 25, 1 September 1996, pp. 4987-4992. Their application required a coating with the following requirements:' C% P7 l2 F4 M/ X
A. Reflectance between 30% and 40% for wavelengths 430-630 nm! `4 ~2 w1 S) X6 d$ M) o! u" R5 @: I
B. Reflectance greater than 97% at 780 nm
" e% R1 p1 v2 U6 SC. Nearly constant phase shift on reflection for wavelengths 430-630 nm
% f/ N* [2 w- d! z8 q7 WThis coating is on glass (index 1.52) and light is at normal incidence. This problem is ideal for the needle/tunneling method because it is not obvious how complex the final design will have to be. Also note that this design problem uses (1) inequality targets for the first requirement and (2) derivative targets for the third requirement (which is the same as requiring the first derivative to be zero for wavelengths 430-630 nm).
6 K& v$ B. t/ oStarting with a single thin layer, the needle/tunneling method found a sequence of 5 optimal designs, the last of which is shown below. The thick line is reflectance; the thin line is phase shift on reflection. Two coating materials were used: H (2.35) and L (1.38). . u, m; F2 b/ c% e
/ K# Y3 Y  H, s* t0 i, m The authors of the paper developed a clever design, whose performance is shown below, using materials H (2.4) and L (1.3). 8 E& b; l' X0 E$ ]. C; p
5 S, v0 \* J; w6 o2 c
Here are the designs, with the first layer closest to the substrate and thickness given in nm. Note that the design found by the needle/tunneling method is much thinner than the authors' design. , v. C* \( O5 i7 B7 [
          TFCalc         Paper
5 |6 R" o, B: F+ w0 G) r! K/ u    L     178.83        200.00& z: I# t* g* @
    H      98.46        108.33
% r# e0 F( h: N    L     144.97        400.00
) M  B/ y, y, c5 ^6 B- v    H      89.65        108.33
$ M, U$ L" d( X' S# J: ?    L     138.21        400.00/ A+ K% S. q/ e; _
    H      89.51        108.33
" p& R' t& h4 x4 F) X    L     140.74        400.00
0 k0 ~0 f% \5 G6 Y6 w    H      96.01        108.339 M. S% h* r; x8 A: Z/ m6 G
    L     131.29        400.00
& W) I6 p, o& M% N* g  Z    H      51.51         54.17
: `% L: v! p( R9 JA design was submitted by Dr. H. Zorc (zorc@olimp.irb.hr), who used TFCalc's global optimization capability to find the best 10-layer design. After local optimization, that design was reduced to 9 layers:
: s; y  r9 j- M           Zorc
& J) K8 `: A4 y2 G" i" k4 V8 X# I    H      99.78  W. ?$ N% t" B  G1 y, i2 Q
    L     146.32( r$ o, k$ A! P4 |; X
    H      89.94
5 o$ |/ e( A2 {8 n! P4 H    L     130.38. G6 s+ |( P& M- i
    H      91.04
1 A. f/ t( W! z0 k+ a    L     126.61+ O3 F( F. j  l3 M. l* U
    H      97.111 l1 I2 `) r5 R( d% C' h
    L     116.07
/ q9 g5 E# ?+ b; k    H      60.55- c' ~2 }2 x3 b, q4 v7 Q1 m$ V8 w3 M
This design, which has fewer layers and which is thinner, also has a slightly better phase shift curve. Thank you, Dr. Zorc
GMT, 2026-5-2 , Processed in 0.024484 second(s), 23 queries .
