[size=+3]Four-Wavelength Bandpass Filter 6 G+ T# X" Q# `
3 B* ?0 p/ f$ W" x' h, E, ?This idea came from a graduate student who needed a bandpass filter for detecting light at four wavelengths: 630, 690, 760, and 885 nm. Between these wavelengths the filter is allowed to transmit 10%. The filter is to be coated on glass having index 1.52. The filter operates at normal incidence. So that the demo version of TFCalc can be used to design this filter, we use SIO2 and TIO2 as the two coating materials. T4 p* X& B; h( g
We use a total of nine optimization targets: eight discrete targets of 100% transmission at each of the four desired wavelengths ±1 nm and one continuous target asking for less than 10% transmission from 600 to 950 nm. Although it may seem contradictory to have a continuous target that includes the eight discrete targets, it works in TFCalc because each discrete target has the same weight as the entire continuous target.
5 m7 z; O+ l J) \3 HThere is no theory for a bandpass filter of this type. Hence we use TFCalc's needle/tunneling optimization to design the filter from "scratch". That is, we start with one thin layer of TIO2 and have TFCalc grow that layer into a filter meeting the requirements. After a few minutes, TFCalc finds a 21-layer design having the transmission curve shown below. ) c9 l& p, x' Y4 t3 T6 y6 H
3 E ]2 Z( I5 u( n# X/ C Here is the design with thicknesses given in nm:
! S$ V: d/ l& e1 Q q7 `4 N( BTIO2 75.13
6 u. a) v, |, I2 _% p8 S' f, ~3 vSIO2 126.59
; h4 z& L6 ]1 q- A7 XTIO2 78.97% M1 v2 n( u3 A& V1 S
SIO2 128.10: X" k" |: o8 f2 U& u: R$ E
TIO2 79.51/ g# \9 M7 t; E" K+ L
SIO2 200.036 q8 D7 F7 E# s c! v" e0 O% B
TIO2 113.53
, h" X: E/ ], p" n: B. b n9 |SIO2 153.01
0 {1 B6 Q: [4 wTIO2 43.45
" n$ X2 k5 c3 [8 {SIO2 20.85
. j# r' z0 e/ b( L. c; eTIO2 84.08! g9 \$ l& [! q, R0 {, N6 S
SIO2 140.53
& f' @- R) H! K2 dTIO2 19.37
+ c1 v: S7 r7 N# L K. `: J4 ^SIO2 59.245 l4 e, o& I) ?; `4 b, c; Q+ P
TIO2 84.745 F& ], n3 Q$ n0 A
SIO2 194.55
/ q0 p! ?8 r- L; xTIO2 122.32
4 L3 f% i* q! f9 O% J7 X" NSIO2 128.32) @( s0 O' q: D5 Q" S1 w3 q$ K
TIO2 79.15& M4 D+ t3 t) x; Q) |3 Y
SIO2 127.49
n! r5 o8 l! y( Q; oTIO2 77.77 |
