查看: 2825|回复: 0
[转贴] Wide Infrared Bandpass Filter
gds 该用户已被删除
发表于 2007-5-14 21:22:34 | 显示全部楼层 |阅读模式
[size=+3]Wide Infrared Bandpass Filter 7 a% T$ v+ _3 i* @4 s3 t% v1 C
[ Contents ] [ Index ] [ Home ] 0 L$ D1 X' a: X+ O6 X
This coating is for light at normal incidence on a germanium substrate (index 4). The requirements are:8 E7 n7 [% P0 H$ O5 W, F. j; C/ E
A. Transmittance  99% for wavelengths 3300-5000 nm
# D8 M, e# k, |C. Transmittance Second, starting with a single thin layer, the needle/tunneling method was used to create a 17-layer short-wave pass filter using requirements B and C. The performance is shown below. / m0 E) A5 _6 g. k" G- r( h
9 B5 W+ t4 d3 ~, k) c( p) ?% o Third, experience shows that it is best to place the short-wave pass filter closest to the substrate and then to append the long-wave pass filter. (The needle/tunneling method "discovers" this fact when the brute-force approach is used.) Before optimizing, the performance is:
" M: I2 g: o) t  `* r5 ?3 U
4 R& G- d& J* f7 l After optimizing this design, the final performance is:
2 c7 B3 a$ H2 l. x# e- L8 I8 R5 [
% q$ Q9 E- ^3 F Here are the designs, with the first layer closest to the substrate and thickness given in nm. With a little more work, it may be possible to eliminated some thin layers.
" }9 O, e' w. _# w' p          Short        Long       Bandpass6 O* m. z3 {/ Q9 J+ n6 v
    ZnS   83.39                     97.336 [+ F) C" F- ?* K" Q
    Ge    48.25                     48.60
! i4 L8 c2 j! Q9 i# {    ZnS  756.31                    761.47" y" Y" s0 U  H1 U% Z
    Ge   403.51                    412.85* w9 T9 l+ T) o3 X% T( Z4 T
    ZnS  710.33                    720.06
( w8 @% |* u9 E    Ge   377.93                    382.28$ X& s5 }9 P; U9 Y8 N
    ZnS  696.05                    705.03& A8 T! ~$ p! t( N
    Ge   370.17                    370.421 O1 a2 r; }8 w' q  _  N6 r
    ZnS  696.91                    709.26, z: a8 V* W; i! W
    Ge   365.05                    358.23
7 O5 F( x4 o7 u; p! i0 P% t    ZnS  705.00                    718.527 z/ @# L& T. a9 V
    Ge   361.44                    353.08
2 W6 H# ?! {6 s; K2 w  [    ZnS  719.03                    724.86+ h! F0 Q7 f# \. k6 p
    Ge   360.53                    360.01' t, X0 \+ k8 I& P. X7 g- W+ S
    ZnS  751.56                    710.47
( m1 Z( R4 V' z: E2 s  ?2 |, T4 ~    Ge   328.61                    398.52
! P4 U* ]# e. _) i5 J* s3 E    ZnS  369.01      158.71        564.95
- L' T8 d+ L! V; z) F    Ge               124.38         40.79) X& r0 K- t. S- Z; n% V& x
    ZnS              260.14        224.72; l5 K8 B6 B( H& Y  C: H) s" ^/ b
    Ge                78.55        125.31
1 l4 y# C# L/ e$ d; E& w) l) O5 h    ZnS              149.33        133.58; }5 V* w4 p: D* [  y
    Ge               102.25         98.28
$ ]& s5 @  b* t/ B5 _9 E" ]# B; |' N    ZnS              235.97        268.218 p: [" X5 W' q- u8 Y
    Ge               145.53        138.25
' z/ |" a$ R! s) I6 W* _; _4 r! `    ZnS              279.07        238.01% ^) g( J3 [. C5 n
    Ge               128.80        125.48
0 u: O" a8 e8 t' g    ZnS              196.52        232.65* t% h) a, _" {
    Ge                67.11         68.54- b+ h& U, h+ A3 e# M  U
    ZnS              159.26        168.55
4 q- x, f8 ~# F: @% S& @6 E    Ge               132.16        150.14; v& o8 [3 n& j0 I4 U. G
    ZnS              271.50        254.28- l4 @/ k1 Q' n' f5 ^; z
    Ge               144.32        125.25& O; w! L3 A  K  g! z8 o. A0 K
    ZnS              281.93        307.19
, O0 U* h2 F, `, c    Ge               149.33        165.16( L" k& o' O4 Z6 g
    ZnS              278.65        256.22
1 k' _5 \# Y! @    Ge               140.79        133.046 S1 D3 \- G# l, p9 M
    ZnS              271.93        289.609 o' |( X# u* u! T; q
    Ge               147.16        147.63& _: f+ m% W9 G- i0 a4 g
    ZnS              276.89        266.047 _" a9 i4 F: N/ J4 }  D  k/ h
    Ge               138.39        134.346 s8 F" b- ?* L' a. h  s$ q
    ZnS              271.52        265.601 ]4 Y2 I& J- o2 P2 Y
    Ge               152.12        156.86; E# m  Y2 `# ~4 L# ]
    ZnS              291.92        294.15
, s7 m' O7 N7 {/ E0 g    Ge               135.69        123.17
, |: P  }0 ?- c    ZnS              249.93        250.12
  A# l6 p2 S0 e9 d    Ge               166.98        178.96
" V. S* V9 n- O) `/ M, W! S+ W    ZnS              553.73        528.64
GMT, 2026-5-2 , Processed in 0.023876 second(s), 23 queries .
