[size=+3]Cold Mirror 9 g# K. z) [$ b" q* b/ l# f) w
[ Contents ] [ Index ] [ Home ] & z+ U, x! f( y4 x4 i+ E& u9 m
A cold mirror reflects short wavelengths and transmits long wavelengths. The are many applications for this type of coating. In this example, we require that the coating consist of layers of SiO2 and TiO2 on a glass substrate and have the following performance at normal incidence: e: q4 C8 [; I% g- f0 r% D$ P# e
> 90% reflectance for 380-750 nm
8 \4 b2 f6 R) N7 BThe prime difficulty with this type of coating is the design of the reflector. After an acceptable reflector has been designed, it is usually easy to extend the transmitting region. For instance, the plot below shows the 21-layer design extended to 2000 nm.
0 B3 H$ {, E% L7 L ! z# E) `$ s( }8 e) g
Here are the designs, starting with the layer closest to the substrate, and with thicknesses given in nm:
9 f8 p3 A# a9 R8 J& yTIO2 44.21 33.76% l$ b3 z. m8 W1 U) W
SIO2 102.57 124.040 X1 p) R' E" q' X K
TIO2 43.97 28.39
# s' u3 Y+ ?& w) WSIO2 73.13 66.366 D! Y4 {. W% T& `1 a! G
TIO2 42.56 51.05# w5 u' m! r6 p+ m
SIO2 82.52 86.41
7 s1 o; I7 m, a7 ]2 tTIO2 48.92 51.97
2 N5 }8 e7 U0 H: k; [& N" ASIO2 87.18 88.77
- q; k2 _8 Z5 uTIO2 46.48 39.55' l# m7 r8 V' u, i6 r+ ~7 Z
SIO2 66.56 70.41# F, y# {2 m: {
TIO2 36.16 36.85
$ d) f; G9 h d8 G* KSIO2 162.54 162.379 O D$ `- Z: H) a7 D: n+ H# m
TIO2 53.07 53.15
* P; ?. Y/ {' w% Q i9 hSIO2 97.19 102.084 W/ b0 o( O, q/ c! Q+ T
TIO2 79.13 81.48
( }- ^9 L# u; MSIO2 102.19 99.640 X% U0 w: I3 R) W3 j
TIO2 67.77 61.86
, `3 c; ^$ \8 f9 K/ h# k$ PSIO2 128.87 137.382 q" I( X3 J( v3 V
TIO2 53.24 51.30" I# R1 W4 d: j6 F& r
SIO2 158.61 191.13
0 t) L1 D9 M4 t* zTIO2 34.40 19.03 |
