查看: 1050|回复: 1
[原创] Broad band antireflection coating on silicon from 1.5 to 6um spectral band
发表于 2007-4-28 20:21:13 | 显示全部楼层 |阅读模式
Broad band antireflection coating on silicon from 1.5 to 6um spectral band5 n% L: C. D* V! i
A. Ghosh *, P.K. Bandyopadhyay
4 H/ U% g5 I2 c) g2 Z* [1 K5 [( X* PInstruments Research and Development Establishment, Raipur Road, Dehra Dun, Uttaranchal 248008, India
+ z, }3 o- i; R8 l4 p/ e! NReceived 24 June 2004. G* X4 A7 Y4 [
Available online 12 October 2004+ n+ k: [: }/ w. o$ H
Abstract" R0 ]) N& S! Y, f
Silicon is one of the easily available, low cost and stable material transmitting in 1.5–6lm spectral band. Silicons
4 W! ]8 o7 y8 T8 L8 z$ Qoptical application includes thermal imaging, motion sensors and forward looking infrared (FLIR) technology. In this
% B1 N, k) y6 P. fwork a broad band antireflection coating on silicon substrate for 1.5–6lm spectral band is reported. In the design, a
, |) e. z$ ~2 y" M( j0 f/ F6 k( _gradient index approach is used which is a very useful tool to achieve broad band antireflection coating. To realize this* G/ z& L4 J4 E7 |6 d5 \
gradient index profile, the refractive index is assumed to increase from 1.45 (thorium fluoride chosen as low index material)
7 n1 R- e; }3 J! ]% cto 3.42 of silicon in five discrete optimized steps. The design was conceived with thorium fluoride as first layer next
4 ^, i5 `& _7 ]: B' c9 j% f  bto air and each other four gradient layers were replaced by two equivalent layer combination of silicon and thorium
! o# d( ]5 G9 kfluoride. This nine layer coating deposited by e-beam evaporation system has a total thickness of only 879nm. Experimental& e7 t/ i8 G  H* E3 L3 R8 a; V
results shows average transmission 96% in 1.5–6lm region on a 5mm thick silicon substrate. This coating also) [: @: k6 B" c9 _( n
has 96.3% transmission in the 1.54lm eye safe laser and 96.5% average transmission in 3–5lm wave bands. The coating  J' x: I3 [" O
was environmentally stable, tested as per MIL standard.  T& p! M6 R/ L" y) t# S* _1 N4 p
 2004 Elsevier B.V. All rights reserved.
& b9 t6 u: Q) eKeywords: Broad band antireflection coating; 1.5–6lm spectral band; Gradient index profile; Two equivalent layer combination;' i& k" o4 c' L5 \9 ]5 s
E-beam evaporation; Eye safe laser; Environmentally stable coating
19
看看
8 {8 [1 f! K( j定一个
GMT, 2025-10-15 , Processed in 0.077602 second(s), 24 queries .
