1461| 3
[原创] Refractive index of thin films of SiO2, ZrO2, and HfO2 as a function of the f |
gds 该用户已被删除
[/free]Refractive index of thin films of SiO2, ZrO2, and HfO2 as a function of the films' mass density
Martin Jerman, Zhaohui Qiao, and Dieter Mergel Applied Optics, Vol. 44, Issue 15, pp. 3006-3012 Keywords (OCIS): (310.1860) Thin films : Deposition and fabrication (310.3840) Thin films : Materials and process characterization (310.6860) Thin films : Thin films, optical properties (310.6870) Thin films : Thin films, other properties Abstract Series of amorphous SiO2, ZrO2 and HfO2 films were prepared by electron-beam evaporation at various oxygen pressures such that the packing density varied from 0.6 to 0.82. Transmittance spectra were evaluated with respect to thickness and refractive index by application of analytical formulas to the interference extrema and by dielectric modeling. The thickness of the films ranged from 150 to 1500 nm. The coefficients of Cauchy and Sellmeier dispersion curves were determined as a function of the packing density. The mass density of the compact amorphous grains was estimated by an effective-medium theory and a general refractivity formula. It is similar to those of the crystalline materials. We used the optical data to design multilayer coatings for laser applications in a broad spectral range, including the UV. [free]
购买主题
本主题需向作者支付 10 RMB金钱 才能浏览
发表于 2006-1-6 13:41:53
显示全部楼层
Re:Refractive index of thin films of SiO2, ZrO2, and HfO2 as a function of th
发表于 2005-12-29 21:07:58
显示全部楼层
发表于 2009-3-13 11:27:39
显示全部楼层
