查看: 958|回复: 1
[原创] Designs of infrared non-polarizing beam splitters
gds 该用户已被删除
发表于 2007-4-3 15:22:59 | 显示全部楼层 |阅读模式
[/free]Designs of infrared non-polarizing beam splitters
When used at oblique angles of incidence, the re?ectance and transmittance of thin ?lms exhibit strong polarization effects(PEs), particularly for the ?lms inside a glass cube, which result from the fact that the tangential components of the electricand magnetic ?elds are continuous across each layer interface. However, for many applications, the PEs are undesirable andshould be reduced. Therefore, the concept of non-polarizing beam splitter (NPBS) is proposed. Up till now, however, mostof the reports of NPBSs are suitable for visible light. Therefore, it is necessary to ?nd out some methods to reduce the PEsfor infrared applications. A design method of the infrared NPBS in a cube is proposed, the theoretical analysis is given,designs for different substrates are demonstrated and the simulations of their optical properties are presented in thispaper.r 2005 Elsevier Ltd. All rights reserved.Keywordsolarization; Non-polarizing beam splitter; Opticalthin ?lm; Re?ection-induced retardance
[free]
购买主题 本主题需向作者支付 10 RMB金钱 才能浏览
1
发表于 2007-4-8 19:07:48 | 显示全部楼层
谢谢!!!!!!!!!!!!!!!!!!!!!
GMT, 2025-10-15 , Processed in 0.027902 second(s), 25 queries .
